Firmware for RM502Q-AE
My I please also have a copy of firmware RM502QAEAAR13A02M4G? Thank you.
It has been sent to your email, please check
RM502QAEAAR11A04M4G_01.006.01.006
Hello Sir, do you know when will this Firmware will be available?
Are you currently facing difficulties?
Well I have now installed the following firmware
RM502QAEAAR13A02M4G_01.001.01.001
I have had some disconnect problems with Tmobile, then I started using AT&T which seems to work. What I really need is Dual SIM support, which seems to be disabled in the R13.
What do you recommend?
Should I keep the R13 or go back to R11?
Can T-mobile SIM cards successfully register with the network?
It can, but after a few hours. There appears to be no internet but modem says connected on T-mobile. Then only a reboot fixes it. Like I mentioned, I have migrated to AT&T and have 2 accounts with them, and wish to have dual SIM capability to use my current device in 2 different scenarios.
Do you know of the status of when Dual SIM function will be available, or in what 5G Modem?
Thank you for your support.
Can you please send me the latest firmware too RM502Q/R13?
I have sent it to your email,please check
Hello. Can I please get the latest firmware for the rm502q-ae with change log please? Thanks!
Hello. Can I please get the latest firmware for the rm502q-ae?
current :RM502QAEAAR11A04M4G_01.005.01.005
I having trouble with T-Mobile dropping internet IP but is corrected via a modem restart. I’m using the following:
RM502QAEAAR11A04M4G_01.002.01.002
Could you please email me the latest firmware to correct the T-Mobile issue. Also any tools and instructions to show how to upgrade the firmware.
Thanks.
I have sent to your email,please try it again
Will you email me the current firmware for my RM502Q-AE?
Current version: RM502QAEAAR11A02M4G_01.003.01.003
Thank you so much.
Hello. I would like to get the latest firmware for the RM502Q-GL module. Here is a screenshot of the command. Thanks!
RM502QGLAAR11A02M4G_01.001.01.001
It’s the latest version of firmware I can find so far
Wasn’t sure if you saw my request above but I figured you just missed it.
Thank you so much.
