I have resent it to your email,pls check
Herbert, Can you please also send me version RM502QAEAAR11A04M4G_01.201.01.201 to so I can back out if necessary?
Could I also please get the latest for the RM502Q-AE? Thank you
I used update number RM500QAEAAR13A02M4G_01.001.01.001
But I am facing some problems with the 5G signal. Can you provide me with other versions? My device is rm500q-ae
@herbert.pan-Q can you please share the latest firmware too?
Currently on RM502QAEAAR13A02M4G
Is there a changelog available?
@herbert.pan-Q can you share what my original firmware wouldāve been? Flashed with the latest and no longer getting any net light and unable to connect to TMO
Serial #: MPY23CV1E000354
What is your initial firmware version?
@herbert.pan-Q - unfortunately I didnāt make a note before upgradingā¦ But a search of the imei in the quectel shows the below
SWļ¼ | RM502QAEAAR11A04M4G |
OCļ¼ | RM502QAEAA-M20-SGASA |
SNļ¼ | MPY23CV1E000354 |
IMEIļ¼ | 867826****75** |
Iāve tried a couple RM502QAEAAR11A04M4G revisionsā¦with no luck
I have sent it to your email,pls try
Can you please also send me newest firmware version RM502QAEAAR11A04M4G
AT+QGMR
Please provide the detailed firmware version
AT+QGMR
RM502QAEAAR11A04M4G_01.006.01.006
Can you please send me the latest firmware?
Current:
AT+QGMR
RM502QAEAAR11A04M4G_01.003.01.003
Hello.
I have a rm502q-ae. Can I be sent the latest version of qflash, windows 10 drivers, latest version firmware, and any other relevant instructions with revision notes for both r11 and r13 versions?
My current FW:
AT+QGMR
RM502QAEAAR11A02M4G_01.003.01.003
Are there downsides to using the latest firmware? Iāve had some issues with carrier aggregation on this modemā¦ achieving a max of 2x CA with all bands. The tower Iām connected to appears to be more robust than only offering 2x CA. Is this something later firmware addresses?
