Firmware for RM500Q-GL and RM502Q-AE
Could you please share the latest firmware available for both RM500Q-GL and RM502Q-AE along with any associated tool that needs to be used to upgrade the firmware in these?
Please see photos of the modules attached below:
Best regards,
Marcin Pluciennik
Dear @marcinhon
Please share your current firmware of your module.
Hi Silvia,
Please find the firmware versions below for both modems:
Thank you
Marcin Pluciennik
Dear @marcinhon
Hi Silvia,
Thank you very much for sending those. I can see there are multiple files within each archive - do you have a guide or instruction which files need to be programmed to the module?
I am planning to use the tool Quectel_Customer_FW_Download_Tool_V6.8_EN to upgrade the modules. Is that correct?
Best regards,
Marcin Pluciennik
Same here @silvia .
My HW revision for the 502Q-AE is:
RM502Q-AE
Revision: RM502QAEAAR13A03M4G
Is there any newer FW for these units? I am having issues in fixing GNSS signal.
Can I also receive a copy of the FW + Update Tools for RM502Q-AE?
