Firmware for RG502Q-EA and EG06ELA
Hello!
Could you please send me the latest firmware for RG502Q-EA. It is installed in the Zyxel NR5101 router.
My current firmware version is: RG502QEAAAR11A03M4G
Thanks!
Got it. Thank you very much!
I have also Zyxel LTE 3301-plus that uses EG06ELA.
Current firmware version is: EG06ELAR03A07M4G
Could you please tell me - is this the latest firmware? If not, could you please send the latest firmware?
I have sent the latest one to your email,pls check
Yes, got it. Thanks !
Currently use nr5101
RG502QEAAAR01A04M4G
This is my current module … please help.. i need an update sir…
Hello, can i have latest firmware for RG502Q-EA?
Hi - can I have the firmware for RG502Q-EA as well please?
I’m currently using the NR5101 with firmware RG502QEAAAR11A03M4G as well.
@herbert.pan-Q could you send me the latest file please?
same here, Zyxel LTE 3301-plus, EG06ELA, with current firmware version: EG06ELAR03A07M4G.
Could you sent me the latest one. Thank you.
