Firmware for RG500L
Hi, I am looking for firmware for RG500L. Can you provide it for me?
Revision:RG500LEUACR04A02M8G_OCPU
Dear @AGYE
Did you use QuecOpen on your side?Did RG500LEUACR04A02M8G_OCPU is your current firmware?
Yes, it is my current firmware version.
Hi @Support-team
RG500L-EU
Revision:RG500LEUACR04A01M8G_OCPU
I also need this firmware as requested above but the above is the exact details as returned when i query ATI
Kindly provide to me at xhamel@hotmail.com
@Support team, I am still counting on your support for RG500L-EA firmware. Thanks
Hi, Pcuk @Puck-Q
Could you help to check this open solution?
Hi @Beulah
Please provide the return value of the following AT commands
AT+QGMR
AT+QKENDC
Br,
Puck
@Puck-Q , Thanks for your quick response. Kindly find the requested information below, thanks.
AT+QGMR
RG500LEUACR04A01M8G_OCPU_T0Z_20.200.20.200
AT+QKENDC
+QKENDC: ENDC_211028
+QKHV: 1,0,0
Hi @Beulah
May I know who released this version(RG500LEUACR04A01M8G_OCPU_T0Z_20.200.20.200) to you?
BTW, for the version, it is actually very new.
Hello, This version came with my device. Nobody released anything to me. i just need firmware to address its LAN port issue. If older version, it doesn’t matter.
thanks in anticipation.
Hi Support Team,
I am still waiting your feedback.
Hello , no need to upgrade, your FW is lastest
Hello, My RJ45 isn’t working on my PC. If not recent then let me downgrade.
Hi @Beulah
I don’t think the version can solve your network port problem, and your version is a customized version. You need to know where your device is obtained from.
Ok thanks. Can i get the AT command manual instead? RG500L-EU
Hi @Beulah
Shared, please check.
I received it.
Hello, can you please help me with the firmware for the following:
RG500LEUAPR04A01M1G_OCPU_BETA20231204_20.001.20.001
thanks.
thanks.
Hi @shahkar_ir & @denkiplangat
I noticed that the version you are asking about is with OCPU. This means it is a QuecOpen solution. If you are in the same situation as described above and want to solve some problems through firmware, the result may not be what you want.
I suggest you should contact the supplier of the equipment and ask them to provide their modified version for you to use, because this will adapt to their hardware. Quectel is only a supplier of modules, not the entire machine or equipment.
Thank you for your understanding.
BR
Puck
