Firmware for NR500-EA
Dear @tv_box
Dear @Jmbb_Rmrz
Dear @Seyedali_Hooshangian
RG500U is a part of router.
We can’t control how to upgrade it in router.
I have sent the firmware to your email, please check.
Dear Silvia, I couldnt update the rom, when I started the programmer, the “SPRD U2S diag” port get blink and disconnected (port disappeared) then the programmer got timeout after 70 secons.
Programmer: QFlash_V7.4
ROM: “udx710_module+initgc+console+sec-user-native_FDDNRSEC_21A.pac”
What should I do?
Thanks,
Sorry, I don’t know how to upgrade with your router, it is better to contact with your router manufacture.
Or you can try to upgrade again on your side.
I have some tips that may help you:
  1. Try with a USB-C to USB-C cable for Data (not cable for charge use).
  2. Reset router and connect only the USB cable when WIFI led is on.
  3. Make sure using the correct drivers for that Router chip RG500U.
  4. Log in as a “root” in website and Enable “USB” option. (Warning: this will turn off Ethernet connection when enabled to restore need a reset)
Hello Sir.. can you email me an update for this firmware..
Dear @Zany
Hi Sir @silvia also have the same version
RG500UEAABxCOMSLICv3.2.2543.12.18
Would you please send me the upgrade file? Thanks
Email: mvp_milo@yahoo.com
Hello can someone send me the latest firmware for my router please. The current version I have is RG500UEAABxCOMSLICv3.4.2731.16.43
Hi Immuffing how did you log in as root? I am able to log in as admin only I think I have the same router as you. RG500UEAABxCOMSLICv3.4.2731.16.43
I’ve found that doesn’t need to enter as a “root” account because the debug page work anyway using any account. Only “root” account does is just pop up this page at the menu. Assuming your router IP address is 192.168.188.1…
Debug try this page:
http://192.168.188.1/home.asp#page/jbc-debug
you can check more interesting hidden features\menus on this git:
https://github.com/leandroadonis86/5G-CPE_NR500-EA-Router
Dear @TGCPA_ACADEMY
Dear @windego40
hi ,Dose anyone can sent me the firmware for nr500-EA or RG500Q-EA ?Thinks very much
tooweng@hotmail.com
RG500UEAABR03A04M4G
hi,Do you have any firmware for zhe NR500-ea ?THINKS
tooweng@hotmail.com
I don’t have it. Maybe I will have it later from unofficial source but I do have some unofficial patch fix.
Hello!
I have firmware RG500UEAABxCOMSLICv3.2.2543.12.18. Can I please send the latest version to fabiofrancotexs@gmail.com?
Dear @robou
Dear @Fabio_Franco
