What is the latest firmware for the EG915U-EU?
I have modules with EG915UEUABR02A05M08 and EG915UEUABR02A04M08
Please send new firmware to sa_muraj@wp.pl
I have sent it to you
How to update via the FOTA tool ?
The uploaded file is too large. The available space in the modem is:
[2024-02-02 14:03:18:341_R:] AT+QFLDS=“UFS”
[2024-02-02 14:03:18:341_R:] +QFLDS: 1409356,1497356
and the uploaded file is 6287360 bytes
There is no other way to connect the modem. The modem is in a device without a USB port.
Please send the EG915UEUABR02A05M08 and EG915UEUABR02A04M08 firmware in order to use DFOTA
HI, I want to update fw via FTP, as I understand I need specific fw file. Can you send me latest fw file for EG915U-EU for FOTA? Thank you.
If you need a differential upgrade package, you need to apply through the purchase channel
Can you clarify? Do I need to buy modem firmware to upgrade? I have EG915U with version EG915UEUABR03A01M08_01.002.01.001, I want a newer one to be able to update via FTP. Why is there no publicly available firmware version, are customers who have bought modems with bugs left without the possibility to update?
I suggest you request DFOTA Differential Upgrade package to support@quectel.com
Most people ask here, I thought maybe someone could send it through the forum. Thanks for the reply. I will contact support.
Hello Quectel support I am using the EG915U-EU module and I would like to request a firmware version (EG915UEUABR03A01M08_01200.01200) / due to a strange problem with the telecommunications network, I was unable to resolve the registration timeout issue with the latest firmware, but with the version I requested, it worked on a modem I had and the same module.
I would like to request a differential firmware update package (delta firmware) for the EG915U-EU module.
Current firmware reported by the module:
EG915UEUABR03A01M08_01.204.0
Due to remote deployment constraints, I am unable to perform a full firmware upgrade and can only update the module using a differential (incremental) firmware package over UART.
Please provide the appropriate latest differential firmware package compatible with this firmware version, along with the recommended upgrade procedure and any required AT command sequence.
If available, please also include the release notes for the latest compatible version.
Thank you in advance for your assistance.
