Firmware for L89HA-S90
I am looking for latest firwmare for L89HA-S90 module (to enable 10Hz output). Can the upgrade be done with quectel toolkit or you can also provide a program for the upgrade.
Thanks!
Hi Knuthcomi,
You can use QGNSS_V1.10_EN | Quectel for firmware upgrading and debugging.
Setting 10 hz update rate:$PAIR050,100*22
The module will change to 10hz output as soon as the command is sent succefully.
And send $PAIR513*3D to save configurations in flash memory.
I will send you the latest firmware via message.
Best regards.
I also need firmware for L89-S90.
Hi Chanchalrajpootaccil,
I will send you the latest firmware for L89-S90 via message.
Best regards.
Hello, I also need the latest firmware
Hi Aruna,
The latest FW for L89HA has been sent to your email.
BR,
June
Hi @June_Zhu,
Thank you for the response. I tried to flash the firmware that you provided, but it showing error.
Thank you
Hi Aruna,
Could you check your current FW and let me know?
Thank you,
June
I also need firmware for L89HA-S90.
kindly share with me the latest firmware of the model …please and also the steps to upgrade it . i want to pair this gps with cuav pixhawk v6x drone fc
Hi There
Firmware:L89HANR01A07S module (to enable 10Hz output). Can the upgrade be done with quectel toolkit or you can also provide a program for the upgrade.
Hi @Swamynath_Suthari can you share you current FW version?
Hi @Rohit_Singh1 please share you current FW version.
Hi @razik_rahman the FW L89HANR01A07S did not enable for 10Hz output. L89HA module max. update rate is 1Hz.
Best regards,
hi @mohamad.firdaus
Can you share the firmware file to do a factory reset
thanks !!
Hi @razik_rahman if you want to restore to default setting, you can use below command:
$PQTMRESTOREPAR*13
$PQTMSAVEPAR*5A
Then restart the module.
Best regards,
@mohamad.firdaus please, mail firmware for l89ha . Thanks
Hi @Dvrj, please check your email I have sent you the latest firmware version with upgrade guide.
Best Regards.
