Hello Quectel Team,
We are integrating EC200UEUAC-N05-SNNSA over USB with an embedded Linux host and building a custom connection manager (cellular-mgr) alongside. Please clarify the following software, firmware, and protocol details for EC200UEUAC-N05-SNNSA:
1. eSIM / eUICC Firmware & AT Command Support
Does the recommended/latest firmware for
EC200UEUAC-N05-SNNSAsupportAT+QESIMcommands (such as querying EID, listing, enabling, disabling, or deleting profiles)? Are there any SKU-specific or firmware-version restrictions? -
How are eSIM profile provisioning, activation, and switching handled in software on
EC200UEUAC-N05-SNNSA(e.g., viaAT+QESIMcommands, an LPA client, or carrier/RSP provisioning), and what URCs or error codes should our daemon monitor during profile changes? -
What AT command sequence is recommended to check eUICC readiness, active profile status, network registration, and PDP/data session state before bringing up the IP interface?
2. Factory Default Configuration
What comes pre-configured from the factory on a brand-new
EC200UEUAC-N05-SNNSAmodule (default USB composition/mode, UART/USB AT port behavior, URC settings, PDP/APN defaults, power-saving/sleep modes, and factory firmware revision)? -
Which configuration changes persist across reboots and
AT&F(factory reset) vs. which ones are volatile or require explicit save/re-apply on boot?
3. Region-Specific Network & Band Handling
For
EC200UEUAC-N05-SNNSA, which frequency bands and radio access technologies are enabled by default in factory firmware, and is automatic scan/selection recommended across target regions? -
How should region-specific network differences be handled in software (for example via
AT+QCFG="nwscanmode",AT+QCFG="band", roaming settings, or eSIM profile /AT+CGDCONTAPN configuration), and are there any region-specific regulatory or carrier quirks ourcellular-mgrshould account for?
