FGH100M kernel Issue
I am working on setting up the access point of wifi halow on Jetson Orin Nano. The kernel module I am using is: 0-rel_1_12_4_2024_Jun_11, running on Linux 5.15
But it fails right after loading the kernel module morse.ko
[ 168.639263] morse_spi spi1.0: morse_spi_mem_write failed (errno=-71)
[ 168.639264] morse_spi spi1.0: morse_spi_reg32_write failed (errno=-71)
[ 168.639578] morse_spi_find_token failed
[ 168.639579] morse_spi_cmd53_read failed
[ 168.639580] morse_spi spi1.0: morse_spi_mem_read failed (errno=-71)
[ 168.639581] morse_spi spi1.0: morse_spi_reg32_read failed (errno=-71)
[ 168.639880] morse_spi spi1.0: Command morse_cmd_health_check 19:141 timed out
[ 168.639887] morse_spi spi1.0: morse_health_check_work: Failed health check (errno=-110)
[ 168.639896] morse_spi spi1.0: morse_mac_restart: Restarting HW
[ 168.639907] morse_spi_find_data_ack failed
[ 168.639908] morse_spi_cmd53_write failed
[ 168.639909] morse_spi spi1.0: morse_spi_mem_write failed (errno=-71)
[ 168.639911] morse_spi spi1.0: morse_spi_reg32_write failed (errno=-71)
[ 168.640274] morse_spi_find_data_ack failed
[ 168.640277] morse_spi_cmd53_write failed
[ 168.640279] morse_spi spi1.0: morse_spi_mem_write failed (errno=-71)
[ 168.640282] morse_spi spi1.0: morse_spi_reg32_write failed (errno=-71)
[ 168.640627] morse_spi_find_data_ack failed
[ 168.640630] morse_spi_cmd53_write failed
[ 168.640632] morse_spi spi1.0: morse_spi_mem_write failed (errno=-71)
[ 168.640634] morse_spi spi1.0: morse_spi_reg32_write failed (errno=-71)
[ 168.660741] morse_spi spi1.0: morse_mac_restart: Generating core-dump (reason:health check failure)
[ 168.661027] morse_spi_find_data_ack failed
[ 168.661029] morse_spi_cmd53_write failed
[ 168.661030] morse_spi spi1.0: morse_spi_mem_write failed (errno=-71)
[ 168.661033] morse_spi spi1.0: morse_spi_reg32_write failed (errno=-71)
[ 168.661127] morse_spi_find_token failed
[ 168.661128] morse_spi_cmd53_read failed
[ 168.661129] morse_spi spi1.0: morse_spi_mem_read failed (errno=-71)
[ 168.661131] morse_spi spi1.0: morse_spi_reg32_read failed (errno=-71)
[ 168.661133] morse_spi spi1.0: morse_coredump: failed to coredump: -5
[ 168.661135] morse_spi spi1.0: morse_mac_restart: Core-dump failed (errno:-5)
It was working perfectly before.
Even when I load kernel module afer restarting the FGH100M, it now fails right after running the command “insmod morse.ko”. How can I debug it?
The issue has been resolved. It was a power supply issue.
Issue resolved.This may also be caused by hardware interference.
