FGH100M C-Drivers or library
Good Day
We are working on a project using your FGH100M-module with an ESP32. Is there any sort of C-driver or library, which would help in the software development? If not, is there a document outlining the SPI-communication of the module?
Thank You
What development environment are you using for the ESP32?
ESP-IDF, Arduino, or a custom FreeRTOS-based system?
What interface do you plan to connect the module to? SPI, SDIO?
What model of ESP32 are you working with? (ESP32-S3, C3, WROOM32, etc.)
We might be able to recommend something based on that.
Thanks for your Response
We are currently planning to use the ESP-IDF, with an SPI Interface on the ESP32-C3.
Any help would be appreciated.
Sorry for the trivial request
but did you (@Group_I) received my private message on October 2nd?
Thanks for reply…
Hello @bamarcant @Group_I @Emre_Karabek , could I have these libraries too? im hardly trying to make work the esp32s3 with the fgh100m but im not able to connect them and create the AP.
any help or documentation would be great!
Thanks guys
Hello Nuntius, U cannot set never into AP on the esp32 (only STA),due of the lack of the esp chip…
more on the valid morsemicro_forum
Regards
Thansk for answering mate,
is there any info about creating the AP for the raspberry?
also using esp32 as client? any documentation?
Thanks sir
Mira la P.M…y abra el enlace https://community.morsemicro.com/latest
mirando alrededor encontré interesante que el viejo
MT7628 es capaz de
pero también
pi zero 2w y Luckfox Pico mini b…
saludos.
