FCM360W module not connecting to WIFI using AT command
Im trying to connect my FCM360W module to Wifi, for which im referring Quectel mannual for AT commands my module is able to scan the available wifi network and even if the desired network is found it is not able to connect to the same network using SSID and password following are the AT commands im trying to use AT+QCFG=“usbnet”,1 , AT+QWSCAN , AT+QWSTA=0, AT+QWSTA=“$WIFI_SSID”,“$WIFI_PASSWORD”, AT+QSTASTAT , AT+QGETIP, and this is the output im getting OK
Found desired Wi-Fi network: WHLB-Guest.
Setting module to STA mode…
ERROR
Setting module to STA mode and connecting to Wi-Fi…
Connection Response:
ERROR
Wi-Fi State:
ERROR
Connection Status:
ERROR
Failed to connect to Wi-Fi. Exiting.
Do you have a FCM360W AT command manual?I think the two commands(AT+QWSTA,AT+QFG) are not included in the manual.To connect WiFi,just one command should be used,which is AT+QSTAAPINFO=<WIFI_SSID>,<WIFI_password>.
