Hi @Waleed_Zafar1
Please check below , I was attached full log.
I was doubted in CK CERT file , I don’t know why its format was misorder and I suspect that misorder was cause of SSL MQTT connection problem. Because If I am using license files getting from EC200U HTTP protocol and write in UFS system in FCM360 , SSL MQTT was connected successfully.
But I am getting license files from FCM360 HTTP protocol and write in UFS system in same FCM360, SSL MQTT was not connect.
So that’s why I suspect that CK file format may be a problem
Because In EC200U getting CK file have uniform order , In FCM360W had ununiform order.
Please check and give a solution for this.
Thanks,
[2024-02-19_09:34:27:084]
[2024-02-19_09:34:28:654]RDY
[2024-02-19_09:34:32:471]
[2024-02-19_09:34:32:471]+QSTASTAT: "WLAN_CONNECTED"
[2024-02-19_09:34:33:213]
[2024-02-19_09:34:33:213]+QSTASTAT: "GOT_IP"
[2024-02-19_09:34:42:070]AT+QVERSION
[2024-02-19_09:34:42:070]+QVERSION: FCM360WAAR01A03
[2024-02-19_09:34:42:070]OK
[2024-02-19_09:34:45:838]AT+QGETWIFISTATE
[2024-02-19_09:34:45:838]+QGETWIFISTATE: ssid="wifitest",bssid="c2:22:1d:51:e5:8d",rssi=-39
[2024-02-19_09:34:45:838]OK
[2024-02-19_09:34:48:296]AT+QGETIP="AP"
[2024-02-19_09:34:48:296]+QGETIP: "0.0.0.0","0.0.0.0","0.0.0.0","192.168.194.188"
[2024-02-19_09:34:48:296]OK
[2024-02-19_09:34:49:431]AT+QGETIP="station"
[2024-02-19_09:34:49:431]+QGETIP: "2401:4900:4DE4:F9CE:E608:E7FF:FE1D:50C7","FE80::C022:1DFF:FE51:E58D","FE80::E608:E7FF:FE1D:50C7","2401:4900:4DE4:F9CE::C0"
[2024-02-19_09:34:49:431]+QGETIP: "192.168.194.7","192.168.194.188","255.255.255.0","192.168.194.188"
[2024-02-19_09:34:49:522]OK
[2024-02-19_09:35:18:496]AT+QHTTPCFG=?
[2024-02-19_09:35:18:496]+QHTTPCFG: "url", <urlstring>
[2024-02-19_09:35:18:496]+QHTTPCFG: "header", <name:value>
[2024-02-19_09:35:18:496]+QHTTPCFG: "auth", <username:password>
[2024-02-19_09:35:18:496]+QHTTPCFG: "sslctxid", (0-5)
[2024-02-19_09:35:18:496]+QHTTPCFG: "rsp/header", (0,1)
[2024-02-19_09:35:18:496]+QHTTPCFG: "rspout/auto", (0,1)
[2024-02-19_09:35:18:512]+QHTTPCFG: "closed/ind", (0,1)
[2024-02-19_09:35:18:617]+QHTTPCFG: "form/option",<name>,<file_name>,<content_type>
[2024-02-19_09:35:18:617]OK
[2024-02-19_09:35:19:530]AT+QHTTPCFG="url","<link>"
[2024-02-19_09:35:19:530]OK
[2024-02-19_09:35:21:335]AT+QHTTPPOST=112,60,60
[2024-02-19_09:35:25:470]CONNECT
[2024-02-19_09:35:27:889]
[2024-02-19_09:35:27:889]OK
[2024-02-19_09:35:29:225]
[2024-02-19_09:35:29:225]+QHTTPPOST: 0,200,2980
[2024-02-19_09:35:34:971]AT+QHTTPREAD=30
[2024-02-19_09:35:34:971]CONNECT
[2024-02-19_09:35:34:987]{"deviceId":"XXXXXXXXXXXXXXXXX","hostName":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX","clientCertificate":"-----BEGIN CERTIFICATE-----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\r\nsMr/HOa/RbDrpzfSrlX3dQJJ8zzZVU4WYHNggW1+Tw==\n-----END CERTIFICATE-----","clientKey":"-----BEGIN RSA PRIVATE KEY-----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\r\nHCPs3mqILU7FwvMAiyLdcU5WSmY8Wb7E78JV4gz8B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\r\nHCPs3Q4x6Cqm/9/uAXI0UnXYb7+Tvwr\r\nGnLBx94Im68ZcfVK6FFV4mqsjIw0B7PuUQ6C5tWPFjKHVWaqAAcoxVvnO7wl63nopqVrgkg=\n-----END RSA PRIVATE KEY-----","clientCertificateExpirationDate":"XXXXXXXXXXXXXXXXXXXXXXXXX"}
[2024-02-19_09:35:38:162]OK
[2024-02-19_09:35:38:162]+QHTTPREAD: 0
[2024-02-19_09:40:09:102]AT+QFLST="UFS:"
[2024-02-19_09:40:09:102]+QFLST: "ca.pem",1314
[2024-02-19_09:40:09:240]+QFLST: "user.pem",1036
[2024-02-19_09:40:09:240]+QFLST: "user_key.pem",1696
[2024-02-19_09:40:09:240]OK
[2024-02-19_09:42:02:691]AT+QFDEL="UFS:user.pem"
[2024-02-19_09:42:02:766]OK
[2024-02-19_09:42:03:841]AT+QFDEL="UFS:user_key.pem"
[2024-02-19_09:42:03:918]OK
[2024-02-19_09:42:05:961]AT+QFLST="UFS:"
[2024-02-19_09:42:05:961]+QFLST: "ca.pem",1314
[2024-02-19_09:42:05:961]OK
[2024-02-19_09:42:54:832]AT+QFOPEN="user.pem"
[2024-02-19_09:42:54:832]+QFOPEN: 1
[2024-02-19_09:42:54:832]OK
[2024-02-19_09:42:57:662]AT+QFWRITE=1,1036
[2024-02-19_09:42:57:678]CONNECT
[2024-02-19_09:42:59:725]
[2024-02-19_09:42:59:725]+QFWRITE: 1036,1036
[2024-02-19_09:42:59:725]OK
[2024-02-19_09:43:03:421]AT+QFCLOSE=1
[2024-02-19_09:43:03:543]OK
[2024-02-19_09:43:20:148]AT+QFOPEN="user_key.pem"
[2024-02-19_09:43:20:164]+QFOPEN: 1
[2024-02-19_09:43:20:179]OK
[2024-02-19_09:43:21:799]AT+QFWRITE=1,1694
[2024-02-19_09:43:21:799]CONNECT
[2024-02-19_09:43:24:959]
[2024-02-19_09:43:24:959]+QFWRITE: 1694,1694
[2024-02-19_09:43:24:959]OK
[2024-02-19_09:43:31:017]AT+QFCLOSE=1
[2024-02-19_09:43:31:108]OK
[2024-02-19_09:43:35:796]AT+QFLST="UFS:"
[2024-02-19_09:43:35:796]+QFLST: "ca.pem",1314
[2024-02-19_09:43:35:796]+QFLST: "user.pem",1036
[2024-02-19_09:43:35:796]+QFLST: "user_key.pem",1694
[2024-02-19_09:43:35:796]OK
[2024-02-19_09:44:11:810]AT+QMTCFG="recv/mode",0,0
[2024-02-19_09:44:11:810]OK
[2024-02-19_09:44:12:797]AT+QMTCFG="ssl",0,1,2
[2024-02-19_09:44:12:797]OK
[2024-02-19_09:44:13:842]AT+QSSLCFG="cacert",2,"UFS:ca.pem"
[2024-02-19_09:44:13:842]OK
[2024-02-19_09:44:14:861]AT+QSSLCFG="clientcert",2,"UFS:user.pem"
[2024-02-19_09:44:14:861]OK
[2024-02-19_09:44:15:814]AT+QSSLCFG="clientkey",2,"UFS:user_key.pem"
[2024-02-19_09:44:15:829]OK
[2024-02-19_09:44:16:831]AT+QSSLCFG="seclevel",2,2
[2024-02-19_09:44:16:831]OK
[2024-02-19_09:44:17:814]AT+QSSLCFG="sslversion",2,4
[2024-02-19_09:44:17:828]OK
[2024-02-19_09:44:18:861]AT+QSSLCFG="ciphersuite",2,0x0035
[2024-02-19_09:44:18:861]OK
[2024-02-19_09:44:19:867]AT+QSSLCFG="ignorelocaltime",2,1
[2024-02-19_09:44:19:867]OK
[2024-02-19_09:44:20:868]AT+QMTOPEN=0,"<HOST>",8883
[2024-02-19_09:44:20:991]OK
[2024-02-19_09:44:21:369]
[2024-02-19_09:44:21:369]+QMTOPEN: 0,-1
[2024-02-19_09:46:37:722]AT+QSSLCFG="seclevel",2,1
[2024-02-19_09:46:37:722]OK
[2024-02-19_09:46:40:802]AT+QMTOPEN=0,"<HOST>",8883
[2024-02-19_09:46:40:832]OK
[2024-02-19_09:46:42:470]
[2024-02-19_09:46:42:470]+QMTOPEN: 0,0
[2024-02-19_09:46:53:114]AT+QSSLCFG="seclevel",2,2
[2024-02-19_09:46:53:114]OK
[2024-02-19_09:46:56:701]AT+QMTOPEN=0,"<HOST>",8883
[2024-02-19_09:46:56:701]OK
[2024-02-19_09:46:56:701]+QMTOPEN: 0,2
[2024-02-19_09:47:05:126]AT+QMTCONN=0,"<client_idx>","<client_ID>",""
[2024-02-19_09:47:05:278]OK
[2024-02-19_09:47:06:139]
[2024-02-19_09:47:06:139]+QMTCONN: 0,2
[2024-02-19_09:47:06:139]+QMTSTAT: 0,1
[2024-02-19_09:47:41:467]AT+QMTOPEN=0,"<HOST>",8883
[2024-02-19_09:47:41:558]OK
[2024-02-19_09:47:42:454]
[2024-02-19_09:47:42:454]+QMTOPEN: 0,-1
