According to the Quectel Product Brochure V8.6, the FCM266D supports TCP, UDP, MQTT, MQTTS, HTTP and HTTPS. Could you please confirm whether these protocols are supported in the standard AT firmware, in QuecOpen, or in both? We could not find an FCM266D AT Commands Manual on the Quectel website or developer portal. The QuecOpen (SDK) General API Development Guide V1.0 that we have only covers flash, SPI flash, timer, watchdog, EasyFlash, file system and low-power APIs; it does not include Wi-Fi, socket, TLS, MQTT or HTTP APIs. Could you please share the FCM266D AT Commands Manual and the QuecOpen networking documentation (Wi-Fi, TCP/UDP, TLS, MQTT, HTTP), together with the QuecOpen SDK and Quick Start Guide?
Hi parin,
I cant share document to you through forum, so i will email the relevant files to your inbox.
Regarding your questions:
(1) Both At and QuecOpen support all the TCP, UDP, MQTT, MQTTS, HTTP and HTTPS protocol.
For the remaining files, refer email.
For the SDK access, you will need to apply through us, will send you the questionnaire through email as well.
