Hello everyone, I’m new to this forum so nice to meet you.
I’m currently working on a device which integrates FC41D module, and I’m using AT+QWSCAN command for FC41D for getting hotspots info.
As per last AT Commands manual I have (2022-09-27), the corresponding command has this response:
+QWSCAN: ,<PSK_type>,,,
where is described only as: Integer type. Wi-Fi signal strength.
From my tests it seems to use the 0-63 range (where 63 is maximum strength) but I haven’t found confirmation anywhere, nor I found the corresponding formula to convert it into dBm negative value.
Any help is appreciated, thank you in advance.
