Hi everyone.FC41D, IS posible get error when wifi password incorrect?
(when use AT+QSTAAPINFODEF or AT+QSTAAPINFO)
Hi Sumen,
There will be no explicit error returned when the password is incorrect. However, you can identify this condition by observing the repeated URCs shown below:
[2026-01-22_15:24:57:579]AT+QSTAAPINFO=<ssid>,<password>
[2026-01-22_15:24:57:706]OK
[2026-01-22_15:24:59:027]+QSTASTAT:SCAN_NO_AP
[2026-01-22_15:25:05:328]+QSTASTAT:SCAN_NO_AP
[2026-01-22_15:25:11:652]+QSTASTAT:SCAN_NO_AP
[2026-01-22_15:25:17:984]+QSTASTAT:SCAN_NO_AP
[2026-01-22_15:25:24:299]+QSTASTAT:SCAN_NO_AP
[2026-01-22_15:25:30:640]+QSTASTAT:SCAN_NO_AP
[2026-01-22_15:25:36:962]+QSTASTAT:SCAN_NO_AP
[2026-01-22_15:25:43:289]+QSTASTAT:SCAN_NO_AP
[2026-01-22_15:25:49:625]+QSTASTAT:SCAN_NO_AP
If you see the +QSTASTAT:SCAN_NO_AP URC being reported repeatedly, it usually indicates that the authentication has failed, commonly due to an incorrect password.
To further verify, you may use the following command to double-check the SSID of available networks to double confirm the SSID parameter for AT+QSTAAPINFO=<ssid>,<password> :
AT+QWSCAN
This allows you to confirm whether the entered SSID is detected by the module and to check the corresponding RSSI of the available access points.
Best regards,
YingCheng
Thanks.
Do you have a recommended RSSI value?
for example It might not connect if it’s below -87dBm.
Best regards
Regarding your query on the minimum RSSI required for a connection, there isn’t one definitive ‘cutoff’ value because it depends on several environmental and configuration factors, including:
- Operating Temperature: Extreme heat can increase the noise floor.
- Modulation & Coding Scheme (MCS): Higher data rates (like 64QAM) require a cleaner signal than lower rates (like BPSK).
- Wi-Fi Protocol & Bandwidth: For example, 802.11ah HaLow has a much lower sensitivity threshold than standard 2.4GHz Wi-Fi.
As a general guideline for the module acting as a Station (STA) in a 2.4GHz environment under normal temperature (20MHz bandwidth, 2.4G ):
- For BPSK (lowest data rate, longest range), the sensitivity is approximately -90 dBm.
- For 64QAM (higher data rate), the requirement is stricter, at approximately -70 dBm.
I have sent you the document for reference through email.
Thank you for useful answer.
Best regards
