I’ve started working with FC41D module, and I want to send data in hex format, not ASCII. I’ve found in the AT commands manual that UDP/TCP mode has the option to change data type to Hex instead of ASCII, but i haven’t found this option when sending through SSL. Is it possible to send through SSL with hex type?
Thank you
you can send hex datas directly and let the SSL server analyse the data as hex
