FC41D BLE RSSI info
I need to scan how many BLE devices are around with FC41D module, using the AT command AT+QBLESCAN, acting as a central device. The problem is that i need to know the RSSI of each device, and this module doesn’t report it, while other WIFI/BT modules, like FCM360W, can report the RSSI. There is a way to obtain the RSSI? Is it a Hardware limitation or it’s something planned to be implemented in the future via firmware update?
Thank you
FC41D standard AT firmware doesnt support
But will it support in the future with a firmware update?
Sorry,there is no such plan at the moment.
Hi Aarroyo,
If this is important for your application, we may need to collect questionnaire from you, and develop a dedicated AT version for you application. Please let us know if this method works for you.
