FC41D - AT+QWSCAN answer is not what is expected
I’m beginning dev with FC41D module in STA mode.
Version used is : FC41D_VERSION:FC41DAAR03A03.bin_202203110937
When I send an AT+QWSCAN to scan the hotspots this is what the module is answering :
CMDRSP:+WSCAN:S24+ de Flora,WPA2_AES_PSK,35,f6:bd:a4:32:29:27 ,1
CMDRSP:+WSCAN:ZCGK_00802,WPA_TKIP_PSK,32,00:1b:93:e2:03:22 ,5
CMDRSP:+WSCAN:ZyXEL NWA1123-AC,WPA2_AES_PSK,32,a0:e4:cb:86:0a:b8 ,11
CMDRSP:+WSCAN:ZyXEL NWA1123-AC,WPA2_MIXED_PSK,25,60:31:97:6f:5a:32 ,1
CMDRSP:+WSCAN:default,WPA2_AES_PSK,20,00:09:b5:27:07:98 ,6
CMDRSP:+WSCAN:ZCGSV2_07801,WPA_TKIP_PSK,13,00:1b:93:c4:1e:79 ,5
When I read the documentation it doesn’t notice that each hotspot reported is beginning with the “CMDRSP:” token.
Is this normal ? Does your documentation has not been updated to reflect this ? does my firmware is the last version ?
Thanks for any answer.
Hello Again,
I found FC41DAAR03A06.bin, upgraded my FC41D dev kit and everything is working as expected … until now.
So the module works as expected after you upgraded
Sure, but it wasn’t easy to find the new firmware. You don’t have a firmware repository.
I will feedback internally
Hi @AlainBridel ,.
Can i know where you purchased our module? If you are a registered buyer, you will be able to access Quectel Support for firmware and document download.
