FC41D AT+QWLANOTA Returns ERROR - Could not found response_code:406
Dear Quectel Support Team,
We are experiencing an issue while trying to update the firmware of our FC41D module using the AT+QWLANOTA command. The command returns an ERROR response.
When reviewing the logs, we noticed the following error message: “Could not found response_code:406”.
Could you please check if this issue is related to the Content-Type, Content-Length, or MIME type settings on our HTTP server?
Below are our current module version, the command executed, and the complete log output:
Complete Logs:
[ATSVR]msg type:1 , msg_point = 0x41eb1c,
_atsvr_input_msg_analysis_handler
_atsvr_handle_input, argv:AT+QWLANOTA, argc:2
_atsvc_command_handle argv:AT+QWLANOTA
uri = http://examplebla.com/wifiota/otas.rbl
port = 80
write over
==lwip_netconn_do_close,state:0
lwip_netconn_do_close_internal, close:1
===before: tcp_close_shutdown_fin, state:4
===after tcp_close_shutdown_fin,state:5
lwip_netconn_do_close_internal, close_finished:1
==lwip_netconn_do_delconn, conn->state:0===
===lwip_netconn_do_delconn,tcp:(nil)
[cx]lwip_close : 807
request epoch time from remote server failed.http_ota download failed.at send res = 0
====FIN_WAIT_1—>TIME_WAIT====
Could you please guide us on how to resolve this error and successfully perform the OTA update?
Thank you for your assistance.
Best regards,
