Hello, I need to use the FC41 module with a greater communication distance by BLE. What would be the best antenna model to be used? In a module that doesn’t have the connector (for testing), can I change the SMD resistors jumper to switch from internal to external antenna and adding the antenna connector?
Hi Ivan_Soares,
You can change the SMD resistors jumper to switch from internal to external antenna and adding the antenna, and we also have FC41D module of using external antenna version.
FC41DAGMD—PCB Antenna
FC41DAFMD—ipex Antenna
FC41DAEMD—module Pin2
The following is our wifi antenna products for your reference.
Thank you very much!
Exactly what I was needing.
