I am trying to connect TCP/UDP connection using em06 and QNavigator but i am getting an error “Fail to activate the context!”.
I was able to connect to the module using Q Navigator and was able to send text messages but i am unable to establish connection using TCP/UDP.
The reason of “Failed to activate the PDP context” could be duplicated activation or registration status fail.
Pleae share the configuration interface of the “HOME” and “TCP/UDP”
MC60 is GSM module. Please choose GSM mode while you open Qnavigator
the main issue is here
can you help !?
You would need to remote ip addr setting in AT+CGDCONT commmand.
here’s the orginal commands:
AT+QIFGCNT=0;+QICSGP=1,“MCINET”;+CGATT?;+ CGDCONT = 1,“IP”,“47.255.239.217”;+QIOPEN=“TCP”,“47.255.239.217”,“1264”
Please remove the ip address from command AT+CGDCONT, that is incorrect format.
You could change it as following:
AT+CGDCONT=1,“IP”,“”
i did as you said, same result ![]()
It just a command configuration issue. Please try reboot after you dochanges.
i do reboot the module every time
there is something interesting .it always takes 2 minutes and 48 seconds to send the data, but when i set a timer using AT+QIAUTOS for 180 seconds it won’t send the data and response ERROR !!
I have the same problem.
Has anyone managed to find the solution?
