when I tried flash to MC60 with using Qflash V4.0 and Qflash V4.13 facing with this problem FAIL, META_ConnectWithTarget_r, [36], BootROM start command passed, but target has no response until timeout
pls give me reply
pls give me reply
Dear Vasu,
About your issue, please double check the following information:
1)Whether your own board or Quectel EVB to test it, if you use your own board, whether you have disconnect the module UART and MCU UART?
2)If you use Quectel EVB, whether you have reset the module after you click START button of Qflash?
3)Whether your connection cable is ok, could you change it to have a try ?
4)If you do not upgrade the firmware, just send AT command to module, whether it can return the right response?
I am getting same error will flashing Application code.
I am using EVB with TE-A having module MC60E-CA-04-BLE…
Existing firmware is MC60ECAR01A03. Able to download this firmware but giving error while downloading application code.Using QFlash V4.0 tool.
Please help
