Factory Reset RM520N-GL (RM520NGLAAR01A08M4G-01.205.01.205 firmware)
Good Day,
I have been trying to figure out how to reset back to Factory settings my RM520N-GL modem. I searched and found the following set of AT commands, but this has not resulted in the modem returning back to factory settings.
AT+QPRTPARA=3
AT+CFUN=1,1
AT+QPRTPARA=1
AT+QCFG=“ResetFactory”
I have also tried reloading the RM520NGLAAR01A08M4G-01.205.01.205 firmware, but this too has not returned the modem back to Factory settings.
Dear @svandive
If these AT commands can’t take effect, we don’t have other commands.
Is there an Application Note that specifically covers this function for the RM520N-GL?
So you’re saying the commands I listed should in fact work on this modem? I don’t have any documentation that clearly tells me this.
Dear @svandive
Which function do you test ? TCP,http or others?
I’m sorry I don’t understand the question. I have a project that I am using these modems for data and location synchronization. I’m not sure if this answers your question.
What I want to confirm is the appropriate procedure to reset the modem back to Factory configuration for all settings using AT commands.
Dear @svandive
For data and location synchronization, which did you use?TCP,HTTP or other protocol. Did you use GNSS?
