HI,
how do i save a sound clip (in format .wav) from modem Quectel EM12 on windows directory?
I tried with this command AT+QFDWL, but it outputs binary data. How do I save the clip from UFS to PC?
Hi
Sorry, AT+QFDWL can only output binary data, there is no AT command to take out. Wav files directly, it is recommended that you attach an SD card or other memory chip to the module side, do not store audio files directly in the MODULE USF storage area, can be stored in SD, easy to take out audio files, thank you.
