I am starting the EC25 manually using the following command:
/vendor/bin/hw/rild -l /vendor/lib64/libril-qc-qmi-1.so -l /vendor/lib64/libreference-ril.so &
When I do that I get the following error messages in the logs:
04-22 06:29:01.939 D/use-Rlog/RLOG-RIL RILC( 3639): QuectelCheckAndroidFrameworkSettingCallback
04-22 06:29:01.939 E/use-Rlog/RLOG-RIL RILC( 3639): Quectel Check: do you install /data/data/com.android.phone ?
04-22 06:29:01.939 E/use-Rlog/RLOG-RIL RILC( 3639): Quectel Check: do you install /system/priv-app/TeleService/TeleService.apk ?
04-22 06:29:01.939 E/use-Rlog/RLOG-RIL RILC( 3639): Quectel Check: do you install /data/data/com.android.providers.telephony ?
04-22 06:29:01.939 E/use-Rlog/RLOG-RIL RILC( 3639): Quectel Check: do you install /system/priv-app/TelephonyProvider/TelephonyProvider.apk ?
04-22 06:29:01.939 D/use-Rlog/RLOG-RIL RILC( 3639): [ro.radio.noril]: [yes]
04-22 06:29:01.939 E/use-Rlog/RLOG-RIL RILC( 3639): Quectel Check: ro.radio.ril must be no, check files /*.prop or /system/*/prop
04-22 06:29:02.102 D/use-Rlog/RLOG-RIL RILC( 3639): settings get global mobile_data 1
04-22 06:29:02.154 D/use-Rlog/RLOG-RIL RILC( 3639): settings get global data_roaming 0
04-22 06:29:02.154 D/use-Rlog/RLOG-RIL RILC( 3639): [persist.radio.multisim.config]: [ssss]
Do I need to fix all of these for the EC25 to work properly on Android 9?
