I have 5G M.2 EVB kit with RM520N-GL module and RTL8111H Ethernet module.
I have connected PC via USB-C and PC is getting correctly IP address 192.168.2.2 defined by Base Station Emulator and IP traffic works fine between this PC and PC behind Base Station (also in same subnet; 192.168.2.x). Also AT commands works fine via USB-C connection.
And ping to EVB kit ethernet module using IP address 192.168.225.1 works ok (and green light is blinking).
However, I would like to change this Ethernet module IP address also to 192.168.2.x that I could access other devices (e.g. IP camera directly or via router) from network side is this possible?
I.e. is there AT command to change this Eth module IP address?
Any other useful AT commands to change behavior of this Ethernet port?
Note: This is closed setup, i.e. no Internet access.
