Evaluation Board for GPIO_32 1 PPS (SIB9) Output
Hi everyone,
Does anyone know of an evaluation board or reference design for Quectel RG50xQ modules that exposes the GPIO_32 1 PPS output (SIB9 timing signal)? Ideally, something that breaks out this pin and can provide the 1 PPS signal for an external timing system. This is for precision timing or synchronized applications.
Dear @khan
Which module do you use? I can share reference design document to you.
Dear @silvia
We are currently in the R&D and component selection phase. Our purchase is strictly dependent on 1 PPS (SIB9) availability. Please provide the recommended model number and Hardware Design documents confirming that GPIO_32 supports this 1 PPS output so we can proceed.
Thanks alot
Dear @khan
For some RGxxx serial, it supports PPS and HD has some description.
But for recommended module, please contact with others, I have sent to you via Message, please try to contact.
Can you please also provide me this information
Dear @MaciejMuehleisen
What is your module? What do you want to know?
5GM2EVB-KIT Evaluation Board (5G-M2 EVB)
RM520N-GL modem with Firmware RM520NGLAAR01A08M4G 01.206.01.206
For RM520N, it doesn’t have PPS pin.
Which R5xx does have a PPS pin for SIB9?
What do you mean of R5xx?
I meant RM5xx meaning modules from the RM500, RM520 or RM530 series.
These modules don’t have PPS pin.
Can you please tell me whcih, if any, Quectel 5G modem supports SIB9 time sync and PPS?
As mentioned before,
