when I was executing the build target command through the eclipse ide I am getting this error please anybody helps me with this error.
please let me know your context codes , and the parameter in this error.
Hi! Even I am facing the same error. I am building the MC60 original SDK which was downloaded online. While building targets, its throwing this error and also .cfg file is not created.
Yes. My module is MC60
I only solved the issue
follow thw documents for the opencpu see first create the opencpu folder or the eclipse only will create the opencpu folder in that copy your project whole folder and now open th eclipse ide and try to run then the isuue will bw solved.
thank you for your sharing
