Hi Quectel Team,
Based on the Android RIL Driver User Guide after adding the libreference-ril.so(version 1.4) in my vendor/lib64/hw there are some error occurs in my logcat for quectel ec200u, help me to solve this error
ERROR ![]()
130|mek_8q:/ # logcat -b radio -v time
[ 296.959451][ T1] init: Control message: Could not find 'android.hardware.radio@1.4::IRadio/slot1' for ctl.interface_start from pid: 318 (/system/bin/hwservicemanager)
[ 297.087360][ T327] logd: logdr: UID=0 GID=0 PID=3815 b tail=0 logMask=2 pid=0 start=0ns deadline=0ns
--------- beginning of radio
01-01 00:00:49.736 D/RILD ( 654): **RIL Daemon Started**
01-01 00:00:49.737 D/RILD ( 654): **RILd param count=3**
01-01 00:00:49.770 D/RILD ( 668): **RIL Daemon Started**
01-01 00:00:49.772 D/RILD ( 668): **RILd param count=1**
01-01 00:00:49.774 D/RILD ( 668): RIL_Init starting sleep loop
01-01 00:00:49.908 D/RILD ( 654): RIL_Init argc = 3 clientId = 0
01-01 00:00:49.908 D/RILC ( 654): Quectel RIL Version: Quectel_Android_RIL_Driver_V3.6.24_master_Release_20231211_10_47
01-01 00:00:49.911 D/RIL_READ_CONF( 654): since '/system/etc/ql-ril.conf' doesn't exsits using '/vendor/etc/ql-ril.conf' but it still doesn't exsits program panic here!
01-01 00:00:49.911 D/RILC ( 654): [ro.build.version.release]: [13]
01-01 00:00:49.911 D/RILC ( 654): Android Version: 130, RIL_VERSION: 12 / 12
01-01 00:00:49.911 E/RILC ( 654): '/vendor/manifest.xml' not exist.
01-01 00:00:49.912 D/RILC ( 654): __getIRadioVersion:673 IRadioVersion:4
01-01 00:00:49.912 D/RILC ( 654): [ro.build.description]: [mek_8q_car2-userdebug 13 TQ1A.230205.002 eng.petsbm.20240920.180851 dev-keys]
01-01 00:00:49.912 D/RILC ( 654): [ro.hardware]: [nxp]
01-01 00:00:49.912 D/RILC ( 654): selinux maybe set Enforcing mode, use command getenforce to check
01-01 00:00:49.912 D/RILC ( 654): selinux maybe set Enforcing mode, use command "setenforce 0" to disable
01-01 00:00:49.912 I/RILC ( 654): clientID = 0
01-01 00:00:49.913 D/RILD ( 654): RIL_Init rilInit completed
01-01 00:00:49.913 I/RILC ( 654): SIM_COUNT: 1
01-01 00:00:49.913 E/RILC ( 654): RIL_register: RIL version 12
01-01 00:00:49.913 I/RILC ( 654): s_registerCalled flag set, 1
01-01 00:00:49.914 D/RILC ( 654): registerService: starting android::hardware::radio::V1_1::IRadio slot1
01-01 00:00:49.922 I/RILC ( 654): RILHIDL called registerService
01-01 00:00:49.922 D/RILD ( 654): RIL_Init RIL_register completed
01-01 00:00:49.922 D/RILD ( 654): RIL_register_socket started
01-01 00:00:49.922 D/RIL_UIM_SOCKET( 654): Adding socket with id: 0
01-01 00:00:49.922 I/RILC ( 654): RIL_register_socket: calling registerService
01-01 00:00:49.922 D/RIL_SAP ( 654): registerService: starting ISap slot1 for slotId 0
01-01 00:00:49.925 D/RIL_SAP ( 654): registerService: started ISap slot1 status 0
01-01 00:00:49.925 D/RILD ( 654): RIL_register_socket completed
01-01 00:00:49.938 I/RILC ( 654): mainLoop Start
01-01 00:00:49.939 D/RILU ( 654): find_pci_device is 0
01-01 00:00:49.939 D/RILC ( 654): PCI can't find at device
01-01 00:00:49.939 D/RILC ( 654): USB can't find at device
01-01 00:00:50.915 D/RILC ( 654): dlopen /vendor/lib64/hw/radio.quectel.module.so failed: dlopen failed: library "/vendor/lib64/hw/radio.quectel.module.so" not found
01-01 00:00:50.915 D/RILC ( 654): start the service through api...
01-01 00:00:50.915 D/RILC ( 654): ql_radio_config_init start
01-01 00:00:50.915 E/RadioConfigFactory( 654): '/vendor/manifest.xml' not exist.
01-01 00:00:50.915 D/RadioConfigImpl( 654): RadioConfigImpl()
01-01 00:00:50.915 D/RadioConfigImpl_1_2( 654): RadioConfigImpl_1_2:registerAsService(default)
01-01 00:00:50.918 D/RadioConfigFactory( 654): radio_config_register_service status=-2147483648
01-01 00:00:50.918 D/RILC ( 654): ql_radio_config_init finish
01-01 00:00:50.918 D/RILC ( 654): ql_radio_sap_init start
01-01 00:00:50.918 D/RIL_SAP_1_2( 654): ql_radio_sap_init() start.
01-01 00:00:50.923 D/RIL_SAP_1_2( 654): radio_sap_register_service status=0
01-01 00:00:50.923 D/RILC ( 654): ql_radio_sap_init finish
01-01 00:00:52.940 D/RILU ( 654): find_pci_device is 0
01-01 00:00:52.940 D/RILC ( 654): PCI can't find at device
01-01 00:00:52.940 D/RILC ( 654): USB can't find at device
01-01 00:00:55.941 D/RILU ( 654): find_pci_device is 0
01-01 00:00:55.941 D/RILC ( 654): PCI can't find at device
01-01 00:00:55.941 D/RILC ( 654): USB can't find at device
01-01 00:00:58.941 D/RILU ( 654): find_pci_device is 0
01-01 00:00:58.942 D/RILC ( 654): PCI can't find at device
01-01 00:00:58.942 D/RILC ( 654): USB can't find at device
01-01 00:01:01.942 D/RILU ( 654): find_pci_device is 0
01-01 00:01:01.942 D/RILC ( 654): PCI can't find at device
01-01 00:01:01.943 D/RILC ( 654): USB can't find at device
01-01 00:01:04.943 D/RILU ( 654): find_pci_device is 0
01-01 00:01:04.943 D/RILC ( 654): PCI can't find at device
09-20 12:41:00.826 D/RILC ( 654): USB can't find at device
09-20 12:41:03.826 D/RILU ( 654): find_pci_device is 0
09-20 12:41:03.826 D/RILC ( 654): PCI can't find at device
09-20 12:41:03.826 D/RILC ( 654): USB can't find at device
09-20 12:41:06.827 D/RILU ( 654): find_pci_device is 0
09-20 12:41:21.835 D/RILU ( 654): find_pci_device is 0
09-20 12:41:21.835 D/RILC ( 654): PCI can't find at device
09-20 12:41:21.835 D/RILC ( 654): USB can't find at device
09-20 12:41:24.836 D/RILU ( 654): find_pci_device is 0
09-20 12:41:24.836 D/RILC ( 654): PCI can't find at device
09-20 12:41:24.836 D/RILC ( 654): USB can't find at device
09-20 12:41:27.836 D/RILU ( 654): find_pci_device is 0
09-20 12:41:27.836 D/RILC ( 654): PCI can't find at device
09-20 12:41:27.837 D/RILC ( 654): USB can't find at device
09-20 12:41:29.914 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:30.837 D/RILU ( 654): find_pci_device is 0
09-20 12:41:30.837 D/RILC ( 654): PCI can't find at device
09-20 12:41:30.838 D/RILC ( 654): USB can't find at device
09-20 12:41:32.946 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:33.838 D/RILU ( 654): find_pci_device is 0
09-20 12:41:33.838 D/RILC ( 654): PCI can't find at device
09-20 12:41:33.839 D/RILC ( 654): USB can't find at device
09-20 12:41:35.470 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:35.524 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:35.751 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:35.894 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:35.945 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:36.246 D/TelephonyRegistry( 748): systemRunning register for intents
09-20 12:41:36.481 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:36.839 D/RILU ( 654): find_pci_device is 0
09-20 12:41:36.839 D/RILC ( 654): PCI can't find at device
09-20 12:41:36.839 D/RILC ( 654): USB can't find at device
09-20 12:41:37.893 W/CarrierConfigManager( 1203): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:39.840 D/RILU ( 654): find_pci_device is 0
09-20 12:41:39.840 D/RILC ( 654): PCI can't find at device
09-20 12:41:39.840 D/RILC ( 654): USB can't find at device
09-20 12:41:41.462[ 297.961261][ T1] init: Control message: Could not find 'android.hardware.radio@1.4::IRadio/slot1' for ctl.interface_start from pid: 318 (/system/bin/hwservicemanager)
09-20 12:41:41.518 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:42.378 D/TelephonyComponentFactory( 1284): validated paths: null
09-20 12:41:42.378 D/TelephonyComponentFactory( 1284): Total components injected: 0
09-20 12:41:42.379 D/TDC ( 1284): updateOrInsert: inserting: Modem { uuid=modem, state=0, rilModel=0, rat={}, maxActiveVoiceCall=1, maxActiveDataCall=1, maxStandby=1 }
09-20 12:41:42.379 D/TDC ( 1284): updateOrInsert: inserting: Sim { uuid=sim, modemUuid=modem, state=0 }
09-20 12:41:42.413 D/PersistAtomsStorage( 1284): PersistAtoms file not found
09-20 12:41:42.435 D/PersistAtomsStorage( 1284): created new PersistAtoms
09-20 12:41:42.444 D/MetricsCollector( 1284): registered
09-20 12:41:42.448 D/CdmaSSM ( 1284): subscriptionSource from settings: 0
09-20 12:41:42.449 I/PhoneFactory( 1284): Cdma Subscription set to 0
09-20 12:41:42.451 I/PhoneFactory( 1284): Network Mode set to 0
09-20 12:41:42.456 D/RILJ ( 1284): RIL: init allowedNetworkTypes=50055 cdmaSubscription=0) [PHONEnull]
09-20 12:41:42.841 D/RILU ( 654): find_pci_device is 0
09-20 12:41:42.841 D/RILC ( 654): PCI can't find at device
09-20 12:41:42.841 D/RILC ( 654): USB can't find at device
09-20 12:41:43.242 W/CarrierConfigManager( 1286): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:43.289 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:41:43.617 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:43.750 D/TelephonyRegistry( 748): notifyCellLocationForSubscriber: subId=2147483647 cellIdentity=null
09-20 12:41:44.424 W/CarrierConfigManager( 1203): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:45.842 D/RILU ( 654): find_pci_device is 0
09-20 12:41:45.842 D/RILC ( 654): PCI can't find at device
09-20 12:41:45.842 D/RILC ( 654): USB can't find at device
09-20 12:41:48.843 D/RILU ( 654): find_pci_device is 0
09-20 12:41:48.843 D/RILC ( 654): PCI can't find at device
09-20 12:41:48.843 D/RILC ( 654): USB can't find at device
09-20 12:41:50.665 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:50.701 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:50.899 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.150 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.405 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.537 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.650 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.795 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.820 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.844 D/RILU ( 654): find_pci_device is 0
09-20 12:41:51.844 D/RILC ( 654): PCI can't find at device
09-20 12:41:51.845 D/RILC ( 654): USB can't find at device
09-20 12:41:51.880 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.922 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:51.977 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:41:54.846 D/RILU ( 654): find_pci_device is 0
09-20 12:41:54.846 D/RILC ( 654): PCI can't find at device
09-20 12:41:54.846 D/RILC ( 654): USB can't find at device
09-20 12:41:57.351 D/TelephonyRegistry( 748): notifyCellLocationForSubscriber: subId=2147483647 cellIdentity=null
09-20 12:41:57.846 D/RILU ( 654): find_pci_device is 0
09-20 12:41:57.847 D/RILC ( 654): PCI can't find at device
09-20 12:41:57.854 D/RILU ( 654): find quectel module /sys/bus/usb/devices/1-1 idVendor=2c7c idProduct=0901
09-20 12:41:57.854 D/RILU ( 654): find_usb_device is 1
09-20 12:41:58.856 D/RILU ( 654): find /sys/bus/usb/devices/1-1:1.2/ttyUSB0
09-20 12:41:58.856 D/RILU ( 654): ttyAT = ttyUSB0
09-20 12:41:58.856 D/RILU ( 654): find /sys/bus/usb/devices/1-1:1.7/ttyUSB5
09-20 12:41:58.856 D/RILU ( 654): ttyPPP = ttyUSB5
09-20 12:41:58.857 D/RILU ( 654): find /sys/bus/usb/devices/1-1:1.3/ttyUSB1
09-20 12:41:58.857 D/RILU ( 654): ttyDM = ttyUSB1
09-20 12:41:58.857 D/RILU ( 654): find /sys/bus/usb/devices/1-1:1.8/ttyUSB6
09-20 12:41:58.857 D/RILU ( 654): ttyGPS = ttyUSB6
09-20 12:41:58.859 D/RILU ( 654): find /sys/bus/usb/devices/1-1:1.0/net/usb0
09-20 12:41:58.860 D/RILU ( 654): usbnet_adapter = usb0
09-20 12:41:58.860 D/RILU ( 654): netcard driver: cdc_ether, driver version: 5.15.74
09-20 12:41:58.860 D/RILU ( 654): ECM = usb0
09-20 12:41:58.860 D/RILC ( 654): quectel at port is /dev/ttyUSB0
09-20 12:41:58.860 D/RILU ( 654): ql_set_autosuspend, enter...
09-20 12:41:58.860 D/RILU ( 654): ro_hardware:nxp
09-20 12:41:58.860 D/RILU ( 654): ----------------------------------------------2:nxp
09-20 12:41:58.860 D/RILU ( 654): ----------------------------------------------3:1
09-20 12:41:58.860 D/RILU ( 654): ----------------------------------------------3:2
09-20 12:41:58.907 D/RILU ( 654): echo on > /sys/bus/usb/devices/1-1/power/control
09-20 12:41:58.907 D/RILU ( 654): ql_set_autosuspend off
09-20 12:41:58.907 D/RILU ( 654): ----------------------------------------------3:3
09-20 12:41:58.907 D/RILU ( 654): ----------------------------------------------3:1
09-20 12:41:58.907 D/RILU ( 654): ----------------------------------------------4
09-20 12:41:58.907 D/RILC ( 654): s_device_path is /dev/ttyUSB0
09-20 12:41:58.924 D/RILC ( 654): open device /dev/ttyUSB0 correctly
09-20 12:41:58.924 E/ATC ( 654): at_open s_tild_reader = 514792492208
09-20 12:41:58.937 D/ATC ( 654): AT> ATE0
09-20 12:41:58.958 D/ATC ( 654): AT< ATE0
09-20 12:41:58.959 D/ATC ( 654): AT< OK
09-20 12:41:58.959 D/ATC ( 654): AT> AT+CMEE=1
09-20 12:41:58.980 D/ATC ( 654): AT< OK
09-20 12:41:58.981 D/ATC ( 654): AT> ATI
09-20 12:41:59.002 D/ATC ( 654): AT< Quectel
09-20 12:41:59.002 D/ATC ( 654): AT< EC200U
09-20 12:41:59.002 D/ATC ( 654): AT< Revision: EC200UCNAAR02A10M08
09-20 12:41:59.002 D/ATC ( 654): AT< OK
09-20 12:41:59.003 D/RILC ( 654): ql_product_version is EC200UCNAAR02A10M08
09-20 12:41:59.003 D/RILC ( 654): Quectel Product Revision: EC200UCNAAR02A10M08
09-20 12:41:59.003 D/RILU ( 654): ql_set_autosuspend, enter...
09-20 12:41:59.003 D/RILU ( 654): ro_hardware:nxp
09-20 12:41:59.003 D/RILU ( 654): ----------------------------------------------2:nxp
09-20 12:41:59.003 D/RILU ( 654): ----------------------------------------------3:1
09-20 12:41:59.003 D/RILU ( 654): ----------------------------------------------3:2
09-20 12:41:59.138 D/RILU ( 654): echo on > /sys/bus/usb/devices/1-1/power/control
09-20 12:41:59.138 D/RILU ( 654): ql_set_autosuspend off
09-20 12:41:59.138 D/RILU ( 654): ----------------------------------------------3:3
09-20 12:41:59.138 D/RILU ( 654): ----------------------------------------------3:1
09-20 12:41:59.138 D/RILU ( 654): ----------------------------------------------4
09-20 12:41:59.138 D/RILC ( 654): UNISOC Platform
09-20 12:41:59.138 D/ATC ( 654): AT> AT+CSUB;+CVERSION
09-20 12:41:59.160 D/ATC ( 654): AT< SubEdition: V07
09-20 12:41:59.160 D/ATC ( 654): AT< VERSION: EC200UCNAAR02A10M08
09-20 12:41:59.160 D/ATC ( 654): AT< Mar 3 2022 09:45:11
09-20 12:41:59.160 D/ATC ( 654): AT< Authors: QCT
09-20 12:41:59.161 D/ATC ( 654): AT< OK
09-20 12:41:59.161 D/ATC ( 654): AT> ATE0
09-20 12:41:59.183 D/ATC ( 654): AT< OK
09-20 12:41:59.183 D/ATC ( 654): AT> at+cmee=1
09-20 12:41:59.205 D/ATC ( 654): AT< OK
09-20 12:41:59.205 D/ATC ( 654): AT> ATS0=0
09-20 12:41:59.226 D/ATC ( 654): AT< OK
09-20 12:41:59.227 D/ATC ( 654): AT> AT+QURCCFG="URCPORT","usbat"
09-20 12:41:59.249 D/ATC ( 654): AT< OK
09-20 12:41:59.250 D/ATC ( 654): AT> AT&D2
09-20 12:41:59.271 D/ATC ( 654): AT< OK
09-20 12:41:59.271 D/ATC ( 654): AT> AT+CMEE=1
09-20 12:41:59.292 D/ATC ( 654): AT< OK
09-20 12:41:59.293 D/ATC ( 654): AT> AT+QCFG="ims",1
09-20 12:41:59.314 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:41:59.314 D/ATC ( 654): AT> AT+CREG=2
09-20 12:41:59.336 D/ATC ( 654): AT< OK
09-20 12:41:59.336 D/ATC ( 654): AT> AT+CREG=2
09-20 12:41:59.357 D/ATC ( 654): AT< OK
09-20 12:41:59.357 D/ATC ( 654): AT> AT+CGREG=2
09-20 12:41:59.379 D/ATC ( 654): AT< OK
09-20 12:41:59.379 D/ATC ( 654): AT> AT+CEREG=2
09-20 12:41:59.400 D/ATC ( 654): AT< OK
09-20 12:41:59.400 D/ATC ( 654): AT> AT+C5GREG=2
09-20 12:41:59.421 D/ATC ( 654): AT< +CME ERROR: 58
09-20 12:41:59.421 D/ATC ( 654): AT> AT+QENDC=1
09-20 12:41:59.443 D/ATC ( 654): AT< +CME ERROR: 58
09-20 12:41:59.443 D/ATC ( 654): AT> AT^DSCI=1
09-20 12:41:59.464 D/ATC ( 654): AT< OK
09-20 12:41:59.464 D/ATC ( 654): AT> AT+CFUN?
09-20 12:41:59.486 D/ATC ( 654): AT< +CFUN: 1
09-20 12:41:59.487 D/ATC ( 654): AT< OK
09-20 12:41:59.487 D/ATC ( 654): AT> AT+CPIN?
09-20 12:41:59.508 D/ATC ( 654): AT< +CME ERROR: 10
09-20 12:42:00.054 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:42:00.152 D/TelephonyRegistry( 748): listen oscl: mHasNotifySubscriptionInfoChangedOccurred==false no callback
09-20 12:42:00.509 D/ATC ( 654): AT> AT+CFUN?
09-20 12:42:00.531 D/ATC ( 654): AT< +CFUN: 1
09-20 12:42:00.531 D/ATC ( 654): AT< OK
09-20 12:42:00.532 I/RILC ( 654): [setRadioState]:oldState=1, newState=2
09-20 12:42:[ 298.963129][ T1] init: Control message: Could not find 'android.hardware.radio@1.4::IRadio/slot1' for ctl.interface_start from pid: 318 (/system/bin/hwservicemanager)
00.543 E/RILC ( 654): radioStateChangedInd: radioService[0]->mRadioIndication == NULL
09-20 12:42:00.543 D/ATC ( 654): AT> AT+CPIN?
09-20 12:42:00.565 D/ATC ( 654): AT< +CME ERROR: 10
09-20 12:42:00.565 I/RILC ( 654): [setRadioState]:oldState=2, newState=3
09-20 12:42:00.566 E/RILC ( 654): radioStateChangedInd: radioService[0]->mRadioIndication == NULL
09-20 12:42:00.567 D/ATC ( 654): AT> AT+QCFG="speed"
09-20 12:42:00.588 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:00.589 D/ATC ( 654): AT> AT+QNWCFG="lte_pco",2
09-20 12:42:00.610 D/ATC ( 654): AT< +CME ERROR: 58
09-20 12:42:00.610 D/ATC ( 654): AT> AT+QIMSCFG="ims_status"
09-20 12:42:00.655 D/ATC ( 654): AT< +CME ERROR: 58
09-20 12:42:00.681 D/SIGNAL_STRENGTH( 654): requestSignalStrength:720 iradio_version = 4
09-20 12:42:00.682 D/ATC ( 654): AT> AT+COPS=3,0;+COPS?;+COPS=3,1;+COPS?
09-20 12:42:00.703 D/ATC ( 654): AT< +CME ERROR: 10
09-20 12:42:00.704 D/ATC ( 654): AT> AT+QENG="servingcell"
09-20 12:42:00.729 D/ATC ( 654): AT< +QENG: "servingcell","LIMSRV","LTE","FDD",404,84,62A9915,420,1357,3,3,3,D620,-90,-7,-67,68,33
09-20 12:42:00.729 D/ATC ( 654): AT< OK
09-20 12:42:00.730 D/CELL_INFO( 654): parseServingCell_234G:699 Enter...
09-20 12:42:00.730 D/ATC ( 654): AT> AT+COPS=3,0;+COPS?;+COPS=3,1;+COPS?
09-20 12:42:00.752 D/ATC ( 654): AT< +CME ERROR: 10
09-20 12:42:00.752 D/CELL_INFO( 654): parseServingCell_234G:767 LTE RSRP=-90
09-20 12:42:00.752 D/CELL_INFO( 654): parseServingCell_234G:802 *count = 1
09-20 12:42:00.752 D/ATC ( 654): AT> AT+CSQ
09-20 12:42:00.776 D/ATC ( 654): AT< +CSQ: 23,99
09-20 12:42:00.776 D/ATC ( 654): AT< OK
09-20 12:42:00.777 D/RADIO_1_4( 654): getSignalStrength_1_4:572 LTE RSRP = 90 RSRQ = 7
09-20 12:42:00.777 D/RILC ( 654): isNetworkInNrEndc 692 Enter: 0
09-20 12:42:00.777 D/RILC ( 654): isNetworkInNrEndc 719 End, is_NR_ENDC:0
09-20 12:42:00.777 E/RILC ( 654): currentSignalStrengthInd: radioService[0]->mRadioIndication == NULL
09-20 12:42:04.610 W/CarrierConfigManager( 1203): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:10.573 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:10.594 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:11.191 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:11.204 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:11.231 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:11.245 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:11.596 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:11.617 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:11.721 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:12.182 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:12.619 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:12.641 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:12.754 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:13.642 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:13.664 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:13.691 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:14.071 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:14.471 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:14.658 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:14.666 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:14.688 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:15.211 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:15.690 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:15.712 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:16.712 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:16.734 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:17.735 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:17.757 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:18.759 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:18.780 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:19.781 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:19.803 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:20.778 D/SIGNAL_STRENGTH( 654): requestSignalStrength:720 iradio_version = 4
09-20 12:42:20.778 D/ATC ( 654): AT> AT+COPS=3,0;+COPS?;+COPS=3,1;+COPS?
09-20 12:42:20.800 D/ATC ( 654): AT< +CME ERROR: 10
09-20 12:42:20.800 D/ATC ( 654): AT> AT+QENG="servingcell"
09-20 12:42:20.826 D/ATC ( 654): AT< +QENG: "servingcell","LIMSRV","LTE","FDD",404,84,62A9915,420,1357,3,3,3,D620,-88,-5,-67,68,35
09-20 12:42:20.826 D/ATC ( 654): AT< OK
09-20 12:42:20.826 D/CELL_INFO( 654): parseServingCell_234G:699 Enter...
09-20 12:42:20.826 D/ATC ( 654): AT> AT+COPS=3,0;+COPS?;+COPS=3,1;+COPS?
09-20 12:42:20.848 D/ATC ( 654): AT< +CME ERROR: 10
09-20 12:42:20.848 D/CELL_INFO( 654): parseServingCell_234G:767 LTE RSRP=-88
09-20 12:42:20.848 D/CELL_INFO( 654): parseServingCell_234G:802 *count = 1
09-20 12:42:20.848 D/ATC ( 654): AT> AT+CSQ
09-20 12:42:20.870 D/ATC ( 654): AT< +CSQ: 23,99
09-20 12:42:20.870 D/ATC ( 654): AT< OK
09-20 12:42:20.871 D/RADIO_1_4( 654): getSignalStrength_1_4:572 LTE RSRP = 88 RSRQ = 5
09-20 12:42:20.871 D/RILC ( 654): isNetworkInNrEndc 692 Enter: 0
09-20 12:42:20.871 D/RILC ( 654): isNetworkInNrEndc 719 End, is_NR_ENDC:0
09-20 12:42:20.871 E/RILC ( 654): currentSignalStrengthInd: radioService[0]->mRadioIndication == NULL
09-20 12:42:20.871 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:20.892 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:20.900 W/CarrierConfigManager( 1203): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:21.892 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:21.915 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:22.916 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:22.938 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:23.405 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:23.435 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:23.815 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:23.914 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:23.939 D/ATC ( 654): AT> at+qcfg="aprstlevel"
09-20 12:42:23.962 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:24.198 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:24.285 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:24.405 W/CarrierConfigManager( 748): Error getting config for subId -1 ICarrierConfigLoader is null
09-20 12:42:35.196 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:35.217 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:36.219 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:36.240 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:37.242 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:37.263 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:38.264 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:38.286 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:39.287 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:39.309 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:40.310 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:40.332 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:40.567 D/RILC ( 654): QuectelCheckAndroidFrameworkSettingCallback
09-20 12:42:40.568 D/RILC ( 654): [ro.radio.noril]: [yes]
09-20 12:42:40.568 E/RILC ( 654): Quectel Check: ro.radio.ril must be no, check files /*.prop or /system/*/prop
09-20 12:42:40.871 D/SIGNAL_STRENGTH( 654): requestSignalStrength:720 iradio_version = 4
09-20 12:42:40.871 D/ATC ( 654): AT> AT+COPS=3,0;+COPS?;+COPS=3,1;+COPS?
09-20 12:42:40.893 D/ATC ( 654): AT< +CME ERROR: 10
09-20 12:42:40.893 D/ATC ( 654): AT> AT+QENG="servingcell"
09-20 12:42:40.919 D/ATC ( 654): AT< +QENG: "servingcell","LIMSRV","LTE","FDD",404,84,62A9915,420,1357,3,3,3,D620,-88,-7,-65,69,35
09-20 12:42:40.919 D/ATC ( 654): AT< OK
09-20 12:42:40.919 D/CELL_INFO( 654): parseServingCell_234G:699 Enter...
09-20 12:42:40.919 D/ATC ( 654): AT> AT+COPS=3,0;+COPS?;+COPS=3,1;+COPS?
09-20 12:42:40.941 D/ATC ( 654): AT< +CME ERROR: 10
09-20 12:42:40.941 D/CELL_INFO( 654): parseServingCell_234G:767 LTE RSRP=-88[ 299.964842][ T1] init: Control message: Could not find 'android.hardware.radio@1.4::IRadio/slot1' for ctl.interface_start from pid: 318 (/system/bin/hwservicemanager)
09-20 12:42:40.941 D/CELL_INFO( 654): parseServingCell_234G:802 *count = 1
09-20 12:42:40.942 D/ATC ( 654): AT> AT+CSQ
09-20 12:42:40.964 D/ATC ( 654): AT< +CSQ: 24,99
09-20 12:42:40.964 D/ATC ( 654): AT< OK
09-20 12:42:40.964 D/RADIO_1_4( 654): getSignalStrength_1_4:572 LTE RSRP = 88 RSRQ = 7
09-20 12:42:40.964 D/RILC ( 654): isNetworkInNrEndc 692 Enter: 0
09-20 12:42:40.964 D/RILC ( 654): isNetworkInNrEndc 719 End, is_NR_ENDC:0
09-20 12:42:40.964 E/RILC ( 654): currentSignalStrengthInd: radioService[0]->mRadioIndication == NULL
09-20 12:42:41.332 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:41.354 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:42.355 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:42.377 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:43.378 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:43.400 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:44.401 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:44.423 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:45.424 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:45.446 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:46.447 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:42:46.469 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:42:47.470 D/ATC ( 654): AT> at+qcfg="modemrstlevel",0
09-20 12:43:00.766 D/ATC ( 654): AT> at+qcfg="dbgctl",1
09-20 12:43:00.788 D/ATC ( 654): AT< +CME ERROR: 3
09-20 12:43:00.965 D/SIGNAL_STRENGTH( 654): requestSignalStrength:720 iradio_version = 4
09-20 12:44:21.523 D/RILC ( 654): isNetworkInNrEndc 692 Enter: 0
09-20 12:44:21.523 D/RILC ( 654): isNetworkInNrEndc 719 End, is_NR_ENDC:0
09-20 12:44:21.523 E/RILC ( 654): currentSignalStrengthInd: radioService[0]->mRadioIndication == NULL
instead of this and repeatedly occuring following error in my logcat
I will attach the manifest.xml file below
<hal format="hidl">
<name>android.hardware.radio</name>
<transport>hwbinder</transport>
<fqname>@1.4::IRadio/slot1</fqname>
<fqname>@1.2::ISap/slot1</fqname>
</hal>
Thanks,
Subash
