I bought the EP06-E module and put it in mikrotik. By standard, it goes in ppp mode, qmi-AT’USBNET,0 (mikrotik with this mode does not work). As without an additional adapter from mini PCIe to usb, change the mode of operation with AT’CFG""USBNET,“0 on AT’SFG”“USBNET”,“1 or AT’SFG”“USBNET”,"2. Interested in exactly how to do it through a command line!!
After using the at+qcfg=“usbnet” command to configure the network card mode, if you still cannot use the network card to access the Internet, please send the following AT command to check the network status to check whether the network status is normal.
AT+CSQ
AT+CPIN?
AT+COPS?
AT+CEREG?
AT+CGREG?
AT+QNWINFO
thanks.
