Dear Support Team ,
I’m sorry because I’m new for EP06-E, I checked from my modem don’t get an LTE signal only WCDMA. how to check config for EP06-E to work for LTE ? my location support freq 1800 and 2100 with provider name Telkomsel.
Dear Support Team ,
Hi godgali:
AT+QCFG=“nwscanmode”,3,1 //The terminal will immediately re-scan the LTE frequency band
And then execute the command:
at+creg? //If the return result is < 0,1>, the network registration is successful
at+cops?
+COPS: 0,0,"???",7 // <???> Refers to the operator you are registered with
If the return result is 7, the terminal is registered on the LTE network.
I suggest you try the above operation. If the problem still cannot be solved, we will keep communicating with you. Thank you.
