Hi, Can you send me the latest FW (I have ID 2c7c:0306 Quectel EP06-E fw. version: EP06ELAR03A08M4G) and how to update it to the module? Thx.
Could you please send me latest firmware and update instructions for EP06-E? My current firmware version is EP06ELAR03A08M4G. Thanks!
KIndly send me the latest firmware for EM06-E
H/W Version: EM06-E
FW/V: EM06ELAR03A05M4G
Hi Herbert,
I also have two PCI-E mini version of the modem EP06ELA-512-SGA
which is still on version EP06ELAR03A08M4G. These are used in an OpenWRT router as backup connections. Can you please send me the latest version of the firmware and few instructions on how to update it?
I need update, since sometimes the modem hangs and need reset from the router to register back to the carrier.
Thanks a lot,
G.
This firmware package is of a large size, I can’t send it to you directly, you need to try to download it again
I have a GL-inet GL-XE300C6 with a EP06-E modem running this firmware : EP06ELAR03A08M4G
Seems like I cannot send SMS with the latest firmware version of this 4G router and it is supposedly linked to the fact that the modem firmware is too old.
May I ask :
- What is the latest possible firmware version ?
- Is it possible to have the firmware changelog for each versions between mine and the latest ?
- What is the firmware upgrade procedure ?
- Is there a way to downgrade if it is not working better/worse ?
Thanks !
I have sent the latest firmware to your email,and update tool
Hello and thanks @herbert.pan-Q
As this mini-PCIe modem is actually in my portable 4G router, I’m pretty sure I’ll have to open it up, extract the modem card and put it in a USB-to-miniPCIe adapter in order to flash the firmware.
Do you agree with that ?
Anyway, are there any chance that I might be able to downgrade the firmware to the initial version in case things are worse than in the initial scenario ?
I have a question regarding the firmware update :
Actually my modem has the F/W version : EP06ELAR03A08M4G
This F/W version starts with EP06ELAR03… and I know there is another one which starts with EP06ELAR04…
You sent me the F/W version EP06ELAR03A20M4G
By any chance, I can update the F/W to the EP06ELAR04… ???
Or should I stick to the EP06ELAR03… variant ?
Thanks !
R03 and R04 belong to different baseline versions and cannot be upgraded across baselines in principle
It is completely operable
EP06-E
Is there a new firmware available?
Thank you beforehand
Current Firmware:
ATI
EM06
Revision: EM06ELAR04A03M4G
Can you please send me link to latest?
EP06
Revision: EP06ELAR04A03M4G
Please, send link to latest firmware.
