EP06-E and EM06-E latest firmwares request
Hi, i am need latest firmware for both modules (mpcie and m.2).
I have sent them to your email,pls check
Hi, i am need latest firmware DFOTA for EP06-E please ?
Today i have get few modems with pre-flashed latest firmware for EP06-E
ATI
EP06
Revision: EP06ELAR04A20M4G
And there is errors with DHCP change ability:
AT+QMAP="LANIP"
ERROR
Failed
AT+QMAP="LANIP",192.168.10.1,192.168.10.2,192.168.10.2
ERROR
Failed
Can you check it?
This problem is beyond my ability, please raise this problem again in the forum
Hello!
Can you please share fw for EP06-E? Current fw version is EP06ELAR03A08M4G
Can I get latest fw for EP06-ALA please, if any? (USA/ATT Version)
(current EP06ALAR02A08M4G_01.004.01.004)
the version is latest by query software library
I have sent it to you by message,pls check
Hello, may I have the latest firmware revision for the EM06-E device, and the software to upgrade it?
My current firmware version is: EM06ELAR03A08M4G
Thank you @herbert.pan-Q , I could managed to update it to EM06ELAR04A20M4G
hi may i ask same copy for EM06-E? Thank you. roddel007@gmail.com
Hello!
Model EP06-E
Firmware revision EP06ELAR04A03M4G
If possible, the latest firmware version.
Thanks in advance!
Thanks. I need firmware for EM06-E pls, not for ep06e.
Sorry,I have resent it to your email,pls check
Hello, may I have the latest firmware revision for the EM06-E?
Current version is: EM06ELAR03A07M4G
Thank you!
