i have a problem with this AT Command.
why it does not work?
I using SC600T-EM
hi,Star2909:
I recommend you use the serial tool to debug and try again
QCOM_V1.6.zip (715.5 KB)
I tried using that tool. When I do send AT command nothing appears
1.Please confirm that the module is correctly installed
2.Check whether the serial port is occupied by another serial port tool
When the kit arrived I installed the drivers present in the key. QNavigator works but QCom no. Do you have any suggestions? Did I forget any steps?
