I am using the RM530N-GL module in 5G-mmWave-EVB v2.2 and cannot make it connect to 5G NSA. LTE and 5G SA on mid band works fine but no NSA neither on midband or mm-wave. Please share a config that enables NSA and mm-wave.
The firmware revision is: RM530NGLAAR01A02M4G
at+qnwprefcfg=“nr5g_disable_mode” returns 0 but at+qeng=“serving cell” only returns the LTE part. at+qendc returns 1,1,0,1,0
Is there any command that checks the mm-wave antenna part of the module to make sure the QTM panels are working properly? at+qmmwscan only returns “OK”
Please also guide me to the most recent AT Commands Manual for this module. I only have ver 1.2 that seems to miss documentations to some commands (such as qmmwscan)
Thanks,
Bengt
