We are planning to use Quectel EG25-G mPCIe module in our project. As per the datasheet in the reference design for the power input of the module is is suggested to use MIC29302WU voltage regulator. This particular voltage regulator has a EN pin which is used to turn ON and OFF the regulator.
So my question is if this particular feature is mandatory for the LDO which will be used for powering up the EG25-G mPCIe module.
