Please share info with me.
I have EM160R-GL with 4 antennas.
Is it available AT-command or other tools to monitor 4G connection parameters during the uploading and downloading data?
modulation 64-QAM or 256-QAM?
MIMI 2x2 or4x4?
My userstory: 4G Base Station supports 256-QAM and MIMO 4x4. I want to know if my module uses 256-QAM and MIMO 4x4 during transmission data.
Currently there is no corresponding AT command to detect the data transmitted by each antenna, maybe you can use CMW500 to monitor the data transmitted by the antenna,thanks.
256 QAM only works if you are very close to the BTS 300mt. maximum in perfect visibility. To understand which modulation your EM160 is using, you need to check the CQI and MCS values and then use a special table to find out the modulation type.
