Not able to disable lte4x4mimo, when run the following command results in error:
AT+QCFG=“lte4x4mimo/disable”,1
ERROR
+QCFG: “lte4x4mimo/disable”,0
modem details:
EM160R-GL
Revision: EM160RGLAUR02A07M4G
Any help appreciated.
thanks
-sam
It is suggested to use **AT+QCFG=“lte4x4mimo/swmethod” to query the current MIMO switch,Then perform AT+QCFG=“lte4x4mimo/disable”, command operation.
Thanks.
@Kerr.Yang-Q Could you please share the syntax for the RM502Q-AE?
I’ve tried the following:
interface/lte/at-chat lte1 input="AT+QNWPREFCFG=\"mode_pref\""
output: +QNWPREFCFG: "mode_pref",LTE:NR5G
and
interface/lte/at-chat lte1 input="AT+QCFG=\"lte4x4mimo/disable\",0"
output: ERROR
Seems like parameters have changed for my 502Q-AE
interface/lte/at-chat lte1 input="AT+QCFG=\"lte4x4mimo/swmethod\""
output: ERROR
