EM12AWPAR01A07M4G mini-pci modem network personalization lock removal
I’ve purchased an EM12-AW mini-PCI modem, but there is a network lock on it show by the output of mmcli:
$ sudo qmicli -p -d /dev/cdc-wdm0 --uim-get-card-status
[/dev/cdc-wdm0] Successfully got card status
Provisioning applications:
Primary GW: slot ‘1’, application ‘1’
Primary 1X: session doesn’t exist
Secondary GW: session doesn’t exist
Secondary 1X: session doesn’t exist
Slot [1]:
Card state: ‘present’
UPIN state: ‘not-initialized’
UPIN retries: ‘0’
UPUK retries: ‘0’
Application [1]:
Application type: ‘usim (2)’
Application state: ‘check-personalization-state’
Application ID:
A0:00:00:00:87:10:02:FF:33:FF:01:89:00:00:01:00
Personalization state: ‘code-required’ (feature: gw-network)
Disable retries: ‘10’
Unblock retries: ‘0’
UPIN replaces PIN1: ‘no’
PIN1 state: ‘disabled’
PIN1 retries: ‘3’
PUK1 retries: ‘10’
PIN2 state: ‘enabled-not-verified’
PIN2 retries: ‘3’
PUK2 retries: ‘10’
How can I unlock it?
I’d also like to ask if there is any newer firmware for the modem. I’m currently on EM12AWPAR01A07M4G
Hi @gman1
May I confirm is the module EM12-AW mini-PCI or EM12-G? based on my checking, we do not have EM12-AW module record.
Its an EM12-AW.
Hi @gman1
Will send you an email to your email address. Kindly check .
