EM120R-GL (PCI-E), latest FW and FW update tool for Windows?
Hello, I have a Lenovo Thinkpad T14 gen 2 (Intel) laptop. Just bought the EM120R-GL PCI-E modem for it specified by Lenovo. It works well under Windows 11 but constantly disconnects and reconnects under Kubuntu 22.04 LTS. Presumably, this could be solved by the latest firmware but I’m not sure how to install it; I read it’s best to do it under Windows. Currently, I’m using the 1.0.0.39 driver (nz7wj13w.exe from Lenovo). The driver package seems to contain some kind of firmware and an executable named FWUpgradeTool_PCIe.exe but it does nothing when executed directly. The parameters from Windows Settings are as follows (parameter names translated back to English):
Manufacturer: Quectel
Model: Quectel EM120R-GL
Firmware: EM120RGLAPR02A03M4G_01.001.07
Network type: 3GPP
Data class: UMTS; HSDPA; HSUPA; LTE
Could you send me links to the proper firmware update tool for Windows and the latest firmware package for the modem?
Hi, Sir
I will send the latest firmware version to you via Email. Thx
For upgrade tool, you may go for following link
Thank you very much! Which of the files in the Toolkit section is used for flashing the firmware on Windows?
The QFlash can be available
Tried running QFlash on Windows 11 with the firmware file you sent me (EM120RGLAPR02A08M4G_01.001.01.001.zip), this is the error I’m getting on the file:
“No Key(json,blf) file is found, this zip file maybe a invalid zip or you downloadmode is not right, please check it.”
The ZIP file itself is technically fine, I can unzip it and see the contents.
Hello Jonathan
Can you send this to me please too?
Quectel EM120R-GL
Could you please specify your current firmware version? Much appreciation
hi - it’s EM120RGLAPR02A07M4G
Thanks.
We have a Dynabook laptop that failed during a firmware update. When using the QFlash application, we get the following error: 'No Key (json, blf) file is found. This zip file may be an invalid zip or your download mode is not correct. Please check it.hi - it’s EM120RGLAPR02A07M4G
I am also running EM120RGLAPR02A07M4G.
Can you please send latest fw?
Thank you.
Could I please get the latest firmware as well?
Hi, can I also have the latest firmware please?
Hello, I am having a Lenovo Thinkpad T14 gen 2 (AMD) laptop. Just bought the EM120R-GL PCI-E, but I cant get it work with Lenovo stock driver package. Everything points to FW mismatch (I can see Quectel EM120R-GL under Network Adapters, Quectel UDE Device, but no COM ports) and the system (Windows11 24H2) identifies Vodafone CZ SIM card, but shows No Service.
Could you also send me the latest firmware file, please?
Thank you
Ondrej
HI can you share latest firmware with me please ?
Hi, I am currently using:
  • Model: Quectel EM120R-GL
  • Current firmware: EM120RGLAPR02A07M4G
  • Platform: Lenovo ThinkPad T480 (Linux)
  • Interface: PCIe / MHI (wwan0mbim0, mhi-pci-generic driver)
Could you please provide the latest version if possible?
Also, I would appreciate it if you could point me to the correct Linux PCIe/MHI driver package for this firmware, since the in-tree driver does not fully support the update/flash process via qfirehose.
Thank you.
Hi @bmt ,
I have reached out to you via email. Please check
Hello I’m using a Quectel EM120R_GL with fedora 44 but the laptop(Lenovo thinkpad x1 yoga g6) has thermal issues during sleep(a lot of mhi errors) and it all points to the outdated firmware version(it currently has the revision EM120RGLAPR02A07M4G). It’s interfacing through PCIe. Could I get the latest firmware version since the installer provided by Lenovo for windows didn’t help.
Hi @bezplacek
Platform: Lenovo ThinkPad T14 Gen 2a
Could you also send me the latest firmware, please?
Same for me. Would appreciate to receive latest firmware for:
Model: EM120R-GL
Current Firmware: EM120RGLAPR02A07M4G
