EM12-G QDLoader
Hello there
I have EM12-G that after start shows only 1 device: Qualcomm HS-USB QDLoader 9008
With VID/PID: USB\VID_05C6&PID_9008&REV_0000
I have tried to flash it with QFlash v4.18, but no luck, i get error:
How to flash FW to this module, any advice? Thanks for answer!
  1. Please first confirm that the EM12-G model information in your hand and the target version information you want to upgrade belong to the same type of EM12-G model. If the EM12-G model is different, the upgrade will fail.
  2. Use the qflash tool to select the USB DM port and select 115200 baud rate for upgrade.
I hope it was helpful. Thank you.
hello there, I’m having the same issue with simcom sim 7600g r2 when i try to flash to it will come up with failed to connect to Sahara server or failed to open serial port.
Any ideas?
Thanks for answer!
1.
2.
Good afternoon! Did you manage to solve the problem? Flash EM12-G
