hello,
I’m a private customer,
I’ve some issue with EM12-G to be too slow compared to cat6 modem I used before (5-10Mbps instead of 80/90Mbps), while I use same technical enviromnent.
Weird thing, AT+QCAINFO shows 3 bands, that means (correct me if I’m wrong) carrier aggregation is working.
so I started looking for information using AT commands.
Starting simple, I was looking for operator list:
AT+CPOL=?
+CME ERROR: 3
so I did check Extended Error Report:
AT+CEER
+CEER: EMM detached
ATI results:
EM12
Revision: EM12GPAR01A19M4G
HI Graziano
Is the module can’t attach the cellular network or attach the cellular network but low speed?
Please help check follow command result, thanks
AT+QNWINFO
AT+COPS?
AT+CSQ
AT+CREG?
AT+CGREG?
I suggest you can change others operator’s SIM to check the status , thanks
