EM061K-GL firmware + official flashing instructions
I have a Quectel EM061K-GL (M.2 Key-B) module and I’d like to update it to the latest generic, non-OEM firmware.
Module info:
Model: EM061K-GL
Current firmware (from host): EM061KGLAAR01A02M2G
USB IDs: VID 2C7C / PID 6008
Usage:
Windows 10 laptop via a USB M.2 Key-B WWAN adapter with SIM slot
Linux SBC (Radxa ROCK 5B+) in the **M.2 Key-B slot with a board SIM socket
Symptoms
On Windows: shows as a Generic Mobile Broadband Adapter, but fails with Code 10 (device cannot start)and there is no Mobile Broadband interface in netsh mbn.
On Linux: detected as cdc_mbim / wwan0, but mbimcli --query-subscriber-ready-status reports sim-not-inserted, even though the SIM works fine in a phone.
Could you please provide:
The recommended latest generic firmware image for EM061K-GL and any official flashing tool and brief procedure for updating / recovering this module over USB (DM / QDLoader). I’m trying to reflash to the latest generic EM061K-GL firmware and get the official Quectel tool + step-by-step procedure for updating / recovering this module over USB (DM / QDLoader), including any required USB-composition settings.
Thanks for you help.
Kind regards, Martin.
Dear Martin,
Thank you for reaching out.
I have sent the latest firmware and the flashing tool together with the flashing procedures via mail.
Kindly check your inbox.
Thank you.
Best Regards,
Aghelan
I would like to ask for the same thing as Martin.
Thank you for your help.
Regards,
Norbert
Dear @Norbert1 ,
Kindly check your mail inbox.
Best Regards,
Aghelan
Hi Aghelan
Would you kindly send me the firware update for the Quectel EM061K-GL and the flashing tool together with the flashing procedures via mail.
Kind regards
Robert
Dear @jzj07828 ,
Best Regards,
Aghelan
Good afternoon
Please send me the Firmware update for Quectel EM061K-GL and the firmware tool along with the firmware procedures by mail.
With respect
Ruslan
Deae @unisovr ,
Best Regards,
Aghelan
Hello! Can You please also send to me? Newest generic firmware and all tools and instructions on how to flash, thanks!
Model: Quectel EM061K-GL
Firmware: EM061KGLAAR01A02M2G
USB ID: VID 2C7C / PID 6008
Hi @aghelan_loga,
Could you please send me the same, latest generic EM061K-GL firmware, the flashing tool, and the flashing procedure, to my email as well?
My module (currently on EM061KGLAAR01A02M2G) is in a Linux setup and has ended up in a USB composition that exposes only ECM + GPS, no AT, DIAG, or MBIM port. With no AT port I can’t reconfigure it back over USB, and this carrier board has no UART routed to the M.2 socket, so a full reflash looks like my only recovery path.
Could you also confirm:
  1. Whether the procedure you send covers recovering a module that has no AT port (i.e. forcing EDL / 9008 mode), and
  2. The on-card test points or pins to force EDL on the EM061K-GL, since I have no UART access.
Thanks very much!
Regards,
can you be so kind to send me the firmware too?
Thank you very much
Hello, I’d like to request the same for my EM061K-GL (M.2 Key-B, current firmware EM061KGLAAR01A02M2G, USB 2C7C:6008).
My module got stuck after AT+QCFG=“usbnet”,0: it now enumerates a malformed composition with no AT/DM port, QMI times out, and DIAG doesn’t respond — so I can’t switch it back to MBIM the normal way. Could you please email me:
  1. The latest generic EM061K-GL firmware (firehose package),
  2. The official flashing tool (QFlash / QFirehose), and
  3. The EDL / QDLoader (9008) recovery procedure, since the normal DM-port method isn’t available to me.
Thank you!
Hi, I have sent an email to your inbox, please check it, thank u.
Hi, I have sent the latest firmware and the flashing tool together with the flashing procedures via mail, please check it, thank u.
@yangwanxin thank you for your interest but I haven’t receive any mail procedure (neither in “my messages” nor via e-mail). Can you be so kind to re-send it? Thank you very
Modem type: Quectel EM061K-GL
Installed Firmware: EM061KGLAAR01A02M2G
USB: VID/PID 2C7C:6008
Hi, could you please specify what kind of materials you need, such as the latest firmware.
I am using Linux and I would like to update the EM061K-GL (EM061KGLAAR01A02M2G) with the latest firmware that support MBIM+NET, AT and the GNSS tty port (exposing NMEA0183 via serial interface). Can you be so kind to send me the firmware, the tool and the instruction on how to update it? thank you very much!
