I have module EM060K-GL with firmware EM060KGLAAR01A11M2G - can i use somehow esim with this module? If yes how to provision profile and how many profiles can be stored?
Regards,
Adam
Regards,
Adam
There is AT command like
AT+QESIM to support the ESIM.
Ok, but i need something more or using AT commands i can “upload” esim profile or something “external” is also needed?
Please check the AT command.
I am not sure whether it works for EM060K. If not, for laster version it might support.
From the AT mannual, you could see that you can enable and disable the profile.
Tried:
AT+QESIM
on:
EM060KGLAAR01A11M2G
but response is:
ERROR
How to enable ESIM functionality?
I have the same module and firmware. The seller told me it supported eSIM. It could be a firmware issue or the seller deceived me.
And eSIM is supported, if i putterd:
into sim slot im able to manage profiles.
