Where can I find the driver files for the android 9.0 environment on GPS?
GNSS driver files, gps_cfg.inf and gps.default.so
Ok, I will send GNSS dirver to you via email, please check.
Thank you, I will try.
can’t get the coordinates of the GPS exactly configured correctly? What port is he using?
01-14 09:26:38.932 D/gps_ql ( 3499): get android version:28
01-14 09:26:46.089 D/gps_ql ( 3499): ql_gps_get_extension(name=gps-xtra)
01-14 09:26:46.089 D/gps_ql ( 3499): ql_gps_get_extension(name=agps_ril)
01-14 09:26:46.090 D/gps_ql ( 3499): ql_gps_get_extension(name=agps)
01-14 09:26:46.091 D/gps_ql ( 3499): ql_gps_get_extension(name=gps_navigation_message)
01-14 09:26:46.092 D/gps_ql ( 3499): ql_gps_get_extension(name=gps_measurement)
01-14 09:26:46.098 D/gps_ql ( 3499): ql_gps_get_extension(name=gps-debug)
01-14 09:26:46.099 D/gps_ql ( 3499): ql_gps_get_extension(name=gps-ni)
01-14 09:26:46.101 D/gps_ql ( 3499): ql_gps_get_extension(name=gnss_configuration)
01-14 09:26:46.116 D/gps_ql ( 3499): ql_gps_get_extension(name=gps_geofencing)
01-14 09:26:46.123 D/gps_ql ( 3499): GPS DRIVER VERSION: Quectel_Android_GPS_Driver_V2.2.5
01-14 09:26:46.128 D/gps_ql ( 3499): [] [rild-nmea] [9600]
01-14 09:26:46.128 D/gps_ql ( 3499): MODULE_TYPE:
01-14 09:26:46.128 D/gps_ql ( 3499): QL_GPS_CHANNEL:rild-nmea
01-14 09:26:46.128 D/gps_ql ( 3499): BAUD_RATE:9600
01-14 09:26:46.129 D/gps_ql ( 3499): init_times = 0, s->init = 0
01-14 09:26:46.129 D/gps_ql ( 3499): ql_gps_state_init start
01-14 09:26:46.130 D/gps_ql ( 3499): Android gps will read from ‘rild-nmea’ channel
01-14 09:26:46.130 D/gps_ql ( 3499): gps state initialized
01-14 09:26:46.135 D/gps_ql ( 3499): ql_gps_xtra_init(callbacks=0xaa69f0a0)
01-14 09:26:46.135 D/gps_ql ( 3499): ql_gps_Xtra_start: gpsXtraCallbacks=0xaa69f0a0
01-14 09:26:46.137 D/gps_ql ( 3499): open GPS channel successful!
01-14 09:26:46.144 D/gps_ql ( 3499): gps thread running
01-14 09:26:46.146 D/gps_ql ( 3499): ql_agps_init[42]–enter!
01-14 09:26:46.146 D/gps_ql ( 3499): ql_agps_init[44]–leave!
01-14 09:26:46.148 D/gps_ql ( 3499): ql_loc_ni_init[26]–enter!
01-14 09:26:46.148 D/gps_ql ( 3499): ql_loc_ni_init[27]–leave!
01-14 09:26:46.148 D/gps_ql ( 3499): ql_loc_agps_ril_init[37]–enter!
01-14 09:26:46.148 D/gps_ql ( 3499): ql_loc_agps_ril_init[38]–leave!
01-14 09:26:46.155 D/gps_ql ( 3499): ql_gps_cleanup()
01-14 09:26:46.155 D/gps_ql ( 3499): report_gps_state enter
01-14 09:26:46.155 D/gps_ql ( 3499): reportStatus GPS_STATUS_SESSION_END
01-14 09:26:46.157 D/gps_ql ( 3499): report_gps_state leave
01-14 09:26:46.157 D/gps_ql ( 3499): report_gps_state enter
01-14 09:26:46.157 D/gps_ql ( 3499): reportStatus to GPS_STATUS_ENGINE_OFF
01-14 09:26:46.162 D/gps_ql ( 3499): report_gps_state leave
01-14 09:26:46.162 D/gps_ql ( 3499): ql_gps_state_done[227]–enter!
01-14 09:26:46.162 D/gps_ql ( 3499): ql_gps_state_stop[240]–enter!
01-14 09:26:46.174 D/gps_ql ( 3499): ql_send_to_target() start
01-14 09:26:46.174 D/gps_ql ( 3499): write command to target
01-14 09:26:46.174 D/gps_ql ( 3499): ql_send_to_target() end
01-14 09:26:46.174 D/gps_ql ( 3499): report_gps_state enter
01-14 09:26:46.174 D/gps_ql ( 3499): reportStatus GPS_STATUS_SESSION_END
01-14 09:26:46.175 D/gps_ql ( 3499): report_gps_state leave
01-14 09:26:46.175 D/gps_ql ( 3499): report_gps_state enter
01-14 09:26:46.175 D/gps_ql ( 3499): reportStatus to GPS_STATUS_ENGINE_OFF
01-14 09:26:46.177 D/gps_ql ( 3499): report_gps_state leave
01-14 09:26:46.184 D/gps_ql ( 3499): ql_agps_set_server[85]–enter!
01-14 09:26:46.184 D/gps_ql ( 3499): agps hostname = supl.google.com, port = 7275
01-14 09:26:46.184 D/gps_ql ( 3499): ql_agps_set_server[102]–leave!
01-14 09:26:46.452 D/gps_ql ( 3499): GPS DRIVER VERSION: Quectel_Android_GPS_Driver_V2.2.5
01-14 09:26:46.452 D/gps_ql ( 3499): [] [rild-nmea] [9600]
01-14 09:26:46.452 D/gps_ql ( 3499): MODULE_TYPE:
01-14 09:26:46.452 D/gps_ql ( 3499): QL_GPS_CHANNEL:rild-nmea
01-14 09:26:46.452 D/gps_ql ( 3499): BAUD_RATE:9600
01-14 09:26:46.456 D/gps_ql ( 3499): init_times = 1, s->init = 1
01-14 09:26:46.457 D/gps_ql ( 3499): ql_gps_xtra_init(callbacks=0xaa69f0a0)
01-14 09:26:46.457 D/gps_ql ( 3499): ql_agps_init[42]–enter!
01-14 09:26:46.457 D/gps_ql ( 3499): ql_agps_init[44]–leave!
01-14 09:26:46.458 D/gps_ql ( 3499): ql_loc_ni_init[26]–enter!
01-14 09:26:46.458 D/gps_ql ( 3499): ql_loc_ni_init[27]–leave!
01-14 09:26:46.459 D/gps_ql ( 3499): ql_loc_agps_ril_init[37]–enter!
01-14 09:26:46.459 D/gps_ql ( 3499): ql_loc_agps_ril_init[38]–leave!
01-14 09:26:46.459 D/gps_ql ( 3499): ql_agps_set_server[85]–enter!
01-14 09:26:46.459 D/gps_ql ( 3499): agps hostname = supl.google.com, port = 7275
01-14 09:26:46.459 D/gps_ql ( 3499): ql_agps_set_server[102]–leave!
01-14 09:27:20.782 D/gps_ql ( 3499): ql_loc_agps_ril_update_network_state[61]–enter!
01-14 09:27:20.782 D/gps_ql ( 3499): ql_loc_agps_ril_update_network_state[62]–leave!
01-14 09:27:20.783 D/gps_ql ( 3499): ql_loc_agps_ril_update_network_availability[67]–enter!
01-14 09:27:20.783 D/gps_ql ( 3499): ql_loc_agps_ril_update_network_availability[68]–leave!
01-14 09:27:20.783 D/gps_ql ( 3499): GpsUtcTime = 0, timeReference = 1464120863, uncertainty=382
01-14 09:27:20.783 D/gps_ql ( 3499): ql_send_to_target() start
01-14 09:27:20.783 D/gps_ql ( 3499): write command to target
01-14 09:27:20.783 D/gps_ql ( 3499): ql_send_to_target() end
01-14 09:27:20.789 D/gps_ql ( 3499): ql_gps_set_position_mode(mode=0, recurrence=0, min_interval=1000, preferred_accuracy=0, preferred_time=0)
01-14 09:27:20.789 D/gps_ql ( 3499): ql_send_to_target() start
01-14 09:27:20.789 D/gps_ql ( 3499): write command to target
01-14 09:27:20.789 D/gps_ql ( 3499): ql_send_to_target() end
01-14 09:27:20.789 D/gps_ql ( 3499): ql_gps_start()
01-14 09:27:20.789 D/gps_ql ( 3499): ql_gps_start: gps_state is 3!
01-14 09:27:20.789 D/gps_ql ( 3499): ql_gps_start: called
01-14 09:27:20.789 D/gps_ql ( 3499): ql_gps_state_start[234]–enter!
'1-14 09:27:21.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N*2C
01-14 09:27:21.583 D/gps_ql ( 3499): report_gps_state enter
01-14 09:27:21.583 D/gps_ql ( 3499): reportStatus GPS_STATUS_ENGINE_ON
01-14 09:27:21.583 D/gps_ql ( 3499): report_gps_state leave
01-14 09:27:21.583 D/gps_ql ( 3499): reportStatus GPS_STATUS_SESSION_BEGIN
01-14 09:27:21.584 D/gps_ql ( 3499): report_gps_state leave
'1-14 09:27:21.586 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:21.586 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:21.588 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:22.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:22.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:22.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:22.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:23.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:23.585 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:23.587 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:23.587 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:24.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:24.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:24.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:24.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:25.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:25.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:25.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:25.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:26.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:26.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:26.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:26.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:27.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:27.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:27.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:27.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:28.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:28.585 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:28.587 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:28.588 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:29.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:29.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:29.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:29.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:30.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:30.582 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:30.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:30.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:31.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:31.584 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:31.585 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:31.586 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:32.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:32.582 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:32.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:32.583 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:33.584 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:33.585 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:33.591 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:33.592 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:34.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:34.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:34.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:34.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:35.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:35.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:35.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:35.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:36.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:36.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:36.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:36.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:37.584 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:37.586 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:37.587 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:37.588 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:38.588 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:38.589 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:38.592 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:38.594 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:39.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:39.582 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:39.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:39.583 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:40.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:40.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:40.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:40.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:41.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:41.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:41.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:41.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:42.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:42.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:42.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:42.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:43.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:43.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:43.587 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:43.588 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:44.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:44.584 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:44.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:44.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:45.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:45.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:45.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:45.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:46.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:46.587 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:46.587 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:46.588 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:47.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:47.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:47.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:47.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:48.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:48.586 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:48.589 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:48.591 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:49.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:49.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:49.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:49.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:50.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:50.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:50.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:50.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:51.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:51.587 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:51.588 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:51.590 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:52.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:52.585 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:52.585 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:52.586 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:53.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:53.585 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:53.589 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:53.590 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:54.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:54.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:54.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:54.583 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:55.584 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:55.588 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:55.589 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:55.590 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:56.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:56.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:56.585 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:56.587 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:57.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:57.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:57.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:57.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:58.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:58.584 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:58.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:58.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:27:59.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:27:59.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:27:59.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:27:59.583 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:00.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:00.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:00.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:00.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:01.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:01.587 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:01.588 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:01.589 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:02.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:02.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:02.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:02.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:03.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:03.584 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:03.585 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:03.586 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:04.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:04.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:04.583 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:04.584 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:05.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:05.586 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:05.586 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:05.587 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:06.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:06.585 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:06.585 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:06.586 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:07.584 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:07.585 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:07.585 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:07.586 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:08.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:08.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:08.586 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:08.587 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:09.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:09.588 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:09.589 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:09.590 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:10.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:10.588 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:10.588 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:10.588 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:11.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:11.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:11.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:11.586 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:12.588 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:12.589 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:12.589 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:12.592 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:13.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:13.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:13.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:13.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:14.584 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:14.585 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:14.586 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:14.587 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:15.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:15.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:15.592 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:15.595 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:16.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:16.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:16.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:16.586 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:17.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:17.584 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:17.588 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:17.589 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:18.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:18.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:18.586 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:18.587 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:19.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:19.590 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:19.590 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:19.592 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:20.582 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:20.583 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:20.584 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:20.585 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:21.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:21.586 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:21.587 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:21.588 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:22.583 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:22.589 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:22.590 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:22.590 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:23.584 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:23.586 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:23.586 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:23.587 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:24.588 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
'1-14 09:28:24.591 D/gps_ql ( 3499): Received: '$GPGSA,A,1,1E
'1-14 09:28:24.600 D/gps_ql ( 3499): Received: '$GPGGA,0,66
'1-14 09:28:24.603 D/gps_ql ( 3499): Received: '$GPRMC,V,N53
'1-14 09:28:25.586 D/gps_ql ( 3499): Received: '$GPVTG,T,M,N,K,N2C
4G is ok. but AGPS and GPS not work
C:\ADB>adb logcat -b radio -v time
01-14 21:15:08.106 I/chatty ( 3963): uid=1001(radio) NetworkService expire 2 lines
01-14 21:15:08.108 D/use-Rlog/RLOG-RIL ATC( 6950): AT< +COPS: 0,0,“MTS BY MTS.BY”,7
01-14 21:15:08.109 D/use-Rlog/RLOG-RIL ATC( 6950): AT< +COPS: 0,1,“MTS BY MTS.BY”,7
01-14 21:15:08.109 D/use-Rlog/RLOG-RIL ATC( 6950): AT< +COPS: 0,2,“25702”,7
01-14 21:15:08.109 D/use-Rlog/RLOG-RIL ATC( 6950): AT< OK
01-14 21:15:08.109 D/use-Rlog/RLOG-RIL RILC( 6950): onRequest: QUERY_NETWORK_SELECTION_MODE
01-14 21:15:08.109 D/use-Rlog/RLOG-RIL ATC( 6950): AT> AT+COPS?
01-14 21:15:08.109 I/chatty ( 3963): uid=1001(radio) HwBinder:3963_1 expire 3 lines
01-14 21:15:08.111 D/use-Rlog/RLOG-RIL ATC( 6950): AT< +COPS: 0,2,“25702”,7
01-14 21:15:08.111 D/use-Rlog/RLOG-RIL ATC( 6950): AT< OK
01-14 21:15:08.111 D/use-Rlog/RLOG-RIL RILC( 6950): onRequest: DATA_REGISTRATION_STATE
01-14 21:15:08.111 D/use-Rlog/RLOG-RIL ATC( 6950): AT> AT+CGREG?
01-14 21:15:08.114 D/use-Rlog/RLOG-RIL ATC( 6950): AT< +CGREG: 2,1,“A0”,“92CC302”,7
01-14 21:15:08.114 D/use-Rlog/RLOG-RIL ATC( 6950): AT< OK
01-14 21:15:08.114 D/use-Rlog/RLOG-RIL RILC( 6950): onRequest: VOICE_REGISTRATION_STATE
01-14 21:15:08.114 D/use-Rlog/RLOG-RIL ATC( 6950): AT> AT+CREG?
01-14 21:15:08.115 I/chatty ( 3963): uid=1001(radio) CellularNetwork expire 6 lines
01-14 21:15:08.118 D/use-Rlog/RLOG-RIL ATC( 6950): AT< +CREG: 2,1,“A0”,“92CC302”,7
01-14 21:15:08.118 D/use-Rlog/RLOG-RIL ATC( 6950): AT< OK
01-14 21:15:08.119 D/use-Rlog/RLOG-RIL ATC( 6950): AT> AT+CSQ
01-14 21:15:08.119 I/chatty ( 3963): uid=1001(radio) HwBinder:3963_1 expire 2 lines
01-14 21:15:08.120 I/chatty ( 3963): uid=1001(radio) com.android.phone expire 63 lines
01-14 21:15:08.123 D/use-Rlog/RLOG-RIL ATC( 6950): AT< +CSQ: 15,99
01-14 21:15:08.123 D/use-Rlog/RLOG-RIL ATC( 6950): AT< OK
01-14 21:15:08.123 D/use-Rlog/RLOG-RIL ATC( 6950): AT> AT+CGREG?
01-14 21:15:08.128 D/use-Rlog/RLOG-RIL ATC( 6950): AT< +CGREG: 2,1,“A0”,“92CC302”,7
01-14 21:15:08.128 D/use-Rlog/RLOG-RIL ATC( 6950): AT< OK
01-14 21:15:21.101 D/use-Rlog/RLOG-RIL RILC( 6950): onRequest: SIGNAL_STRENGTH
