Hi, is there a way to disable the WWAN_LED pin on the EM06?
I’m using an extension board (Khadas New M2X Extension) which has an LED connected to the WWAN_LED pin on the EM06 module. Is there a way to disable this pin, maybe by some AT command, so the LED is disabled.
The current method is just to physically remove the LED from the extension board.
Hello hanskr, thanks for your question
We do not have an AT command that can directly operate the WWAN_LED pin. The WWAN_LED pin is active at low level. You can fly this pin to high for testing, thank you.
