Hi, I have EM05-E module connected to USB2 on STM32mp1 linux board.
I have integrated the driver according your Guide(Quectel_LTE&5G_Linux_USB_Driver_User_Guide_V2.0)
The module working but I have one specific issue with the boot sequence.
when i start up the board after power off the EM05-E module doing this for 11 times until it stables:
[ 39.672515] usb 2-1: USB disconnect, device number 6
[ 39.682640] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 39.706149] option 2-1:1.0: device disconnected
[ 39.735443] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 39.757300] option 2-1:1.1: device disconnected
[ 39.773662] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 39.820131] option 2-1:1.2: device disconnected
[ 39.848212] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 39.879592] option 2-1:1.3: device disconnected
[ 40.477067] usb 2-1: new high-speed USB device number 7 using ehci-platform
[ 40.701322] option 2-1:1.0: GSM modem (1-port) converter detected
[ 40.707951] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 40.724471] option 2-1:1.1: GSM modem (1-port) converter detected
[ 40.737268] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 40.744205] option 2-1:1.2: GSM modem (1-port) converter detected
[ 40.756400] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 40.773061] option 2-1:1.3: GSM modem (1-port) converter detected
[ 40.784793] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 45.291610] usb 2-1: USB disconnect, device number 7
[ 45.296345] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 45.337220] option 2-1:1.0: device disconnected
[ 45.347482] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 45.361764] option 2-1:1.1: device disconnected
[ 45.398472] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 45.417253] option 2-1:1.2: device disconnected
[ 45.422849] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 45.467233] option 2-1:1.3: device disconnected
[ 46.096996] usb 2-1: new high-speed USB device number 8 using ehci-platform
[ 46.321386] option 2-1:1.0: GSM modem (1-port) converter detected
[ 46.328470] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 46.342252] option 2-1:1.1: GSM modem (1-port) converter detected
[ 46.357801] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 46.377123] option 2-1:1.2: GSM modem (1-port) converter detected
[ 46.383394] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 46.399099] option 2-1:1.3: GSM modem (1-port) converter detected
[ 46.405175] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 50.911378] usb 2-1: USB disconnect, device number 8
[ 50.919373] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 50.929206] option 2-1:1.0: device disconnected
[ 50.942532] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 50.959400] option 2-1:1.1: device disconnected
[ 50.980421] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 50.996786] option 2-1:1.2: device disconnected
[ 51.016284] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 51.027582] option 2-1:1.3: device disconnected
[ 51.686985] usb 2-1: new high-speed USB device number 9 using ehci-platform
[ 51.901551] option 2-1:1.0: GSM modem (1-port) converter detected
[ 51.910008] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 51.919847] option 2-1:1.1: GSM modem (1-port) converter detected
[ 51.928821] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 51.935310] option 2-1:1.2: GSM modem (1-port) converter detected
[ 51.941868] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 51.948494] option 2-1:1.3: GSM modem (1-port) converter detected
[ 51.954257] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 55.191789] wlcore: WARNING no fw rx ba on tid 3
[ 56.533120] usb 2-1: USB disconnect, device number 9
[ 56.541832] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 56.566660] option 2-1:1.0: device disconnected
[ 56.587180] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 56.594052] option 2-1:1.1: device disconnected
[ 56.641426] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 56.671163] option 2-1:1.2: device disconnected
[ 56.702211] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 56.730685] option 2-1:1.3: device disconnected
[ 57.367019] usb 2-1: new high-speed USB device number 10 using ehci-platform
[ 57.591173] option 2-1:1.0: GSM modem (1-port) converter detected
[ 57.596560] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 57.611307] option 2-1:1.1: GSM modem (1-port) converter detected
[ 57.616732] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 57.630186] option 2-1:1.2: GSM modem (1-port) converter detected
[ 57.635594] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 57.648810] option 2-1:1.3: GSM modem (1-port) converter detected
[ 57.654218] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 62.155340] usb 2-1: USB disconnect, device number 10
[ 62.162080] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 62.170553] option 2-1:1.0: device disconnected
[ 62.183396] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 62.197364] option 2-1:1.1: device disconnected
[ 62.223382] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 62.259861] option 2-1:1.2: device disconnected
[ 62.279152] wlcore: WARNING no fw rx ba on tid 1
[ 62.321318] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 62.343537] option 2-1:1.3: device disconnected
[ 62.946951] usb 2-1: new high-speed USB device number 11 using ehci-platform
[ 63.161108] option 2-1:1.0: GSM modem (1-port) converter detected
[ 63.180682] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 63.189321] option 2-1:1.1: GSM modem (1-port) converter detected
[ 63.196092] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 63.214028] option 2-1:1.2: GSM modem (1-port) converter detected
[ 63.223839] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 63.236421] option 2-1:1.3: GSM modem (1-port) converter detected
[ 63.243919] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
only then I can connect to the network .
if I only reboot the linux without power off the board conects on the first time:
[ 3.210434] option 2-1:1.0: GSM modem (1-port) converter detected
[ 3.215621] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 3.222702] option 2-1:1.1: GSM modem (1-port) converter detected
[ 3.228541] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 3.235470] option 2-1:1.2: GSM modem (1-port) converter detected
[ 3.241766] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 3.248419] option 2-1:1.3: GSM modem (1-port) converter detected
[ 3.254584] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
Is this some HW issue or may be old firmware?
Firmware: AT+GMR
EM05EFAR06A04M4G
tnx for advance.
Sergey.M
I was more interested in hardware details, I don’t think the issue is OS related.
From my perspective Raspberry is not a good candidate for testing and troubleshooting, I recall having similar issues with my RPi 3B and a comparable modem.
Your Linux desktop if you have one or your Win machine booted from Linux Live USB.
Router or SBC running Linux may do the job as well, but only if you’re confident in its capabilities. For example, I wouldn’t use my RaspberryPi or OrangePi in such situation, however I’ll trust my Alix or APU board.
