I’d like to activate sleep mode for Quectel EM05-G module. But, I’m confused about the documentation. The Software document mentions AT+QSCLK=1, with pulling up WAKEUP_IN and DTR, but these pins are not found in the hardware design doc. Could you please clarify? Also, how can I check sleep mode activation, set sleep period, and monitor power consumption?
Could you kindly address my initial inquiry regarding the inconsistency in the Software and Hardware documents, specifically concerning the pins? Additionally, can we modify sleep mode parameters such as sleep/awake periods and monitor power consumption? I appreciate your response in English.
hi,
What is your current firmware version? In addition, you said that the software does not match the hardware manual. Did you read the wrong module? I will send you a new hardware manual by email.
