Dears,
I am currently running a EM05-G with firmware EM05EFAR06A05M4G.
In order to design in EM05-G into a customer product, we need to validate that the firmware can actually be updated via QFlash.
Can you please provide two different FW versions for EM05-G so I can try to change between those two versions with QFlash?
Thank you,
Thomas
Please help to provide the FW for EM-05G, or we might not be able to use this module in our design.
I have sent them to your email,pls check
Thank you, got it!
Is there also a newer QFlash version for Linux? The one I have is v2.0.0.
BR,
Thomas
Thank you. Since you have provided QFirehose, do you suggest using QFirehose instead of QFlash?
QFlash be used on windows
In the meantime I have built QFirehose on Linux and have successfully updated the firmware - it worked without any issues. Thank you very much for your support!
